Spec Cayman Racing
#46
GT3 player par excellence
#47
Hope I am not overstepping rules here...but I would like to make something perfectly clear. The "Cayman Interseries Championship" is to be run in HSR. Porsche AG, PCNA or Porsche Motorsport is not involved in any way. This is a program that HSR has been working long and hard to develop and has been formed expressly by me and sponsored by Napleton Porsche. Although the cars fit into many race groups with SCCA, Porsche Club,NASA,etc.,the purpose of the series was to make available cars that were ready to be modified and have cool single marque championship series to run in HSR. Thanks, Ron Barnaba
#48
I don't get why there are so many spec series starting. Isn't this just going to dilute racing. There's 944 spec, SPBOX, 996 spec? (haven't researched it at all, just heard rumors), spec Miata, Spec Focus, spec Neon which recently calapsed, Formula Enterprise, now a spec Cayman. With all these spec classes and only a limited number of drivers won't the racers just spread out within whats available. The whole purpose of a spec class is for it to be a driver's/racing class, but if there are fewer racers in each class doesn't that defeat the purpose.
I understand that classes like SM can get out of hand, but with 944 spec and SPBOX just getting started there is still parity within the class. Why are we trying to provide another option? Maybe I'm dense, but I don't quite get it.
#49
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
Here is the latest revision 4/09
Only 2009/2010 Cayman and Cayman”S” cars are eligible. Must compete with full road equipment and, with the
exception of exhaust/emissions, be street legal as designed by the factory, capable of being registered for street use in the condition of the car when presented at scrutineering, and capable of being driven to and from the event. All cars are required to have a Historic paint scheme. [Example; Martini Racing, Rothmans, Gulf, Hippie Car, etc.]
1. Engine
A. As delivered from factory. No modifications after the air filter or before the exhaust muffler.
B. Stock, fuel injection must be retained.
C. Air conditioning belts, hoses, condensers, compressors may be removed.
D. Radiators are free. Radiators must be installed in the stock location. Anti-freeze is prohibited.
E. Any dual mass flywheel may be replaced with a single mass, ferrous material (magnetic) flywheel. Clutch disc
must remain stock diameter.
F. An underdrive pulley { GT3 type}on the crankshaft for the power steering belt may be used.
2. Suspension
A. Suspension pick-up points must remain as stock in location and type.
B. Additional flat metal may not be welded to reinforce suspension mounting points or suspension pieces. Added
material may not connect with roll cage components or otherwise provide chassis stiffening .
C. Shocks and springs must be series spec {TBA}
D. Any suspension setting not requiring machining or modification of factory parts is allowed.
E. Sway bar sizes and configuration must be series spec. {TBA}
F. Suspension bushing materials are free. Replacement of suspension bushings cannot alter the suspension
geometry of the vehicle.
G. Any bolt-in shock tower brace is allowed.
H. Toe links/bump steer links may be replaced
I. OEM two-piece lower control arms {GT3 Type} are allowed.
J. Front and rear uprights must remain stock.
3. Tires and Wheels
A. Only the series spec tire will be approved. [TBA]
B. Tread must be a minimum 2/32” over 2/3 of the tire at the start of each session (practice, qualifying, race).
There must be visible tread remaining on the contact surface of the tire at the end of each session.
C. Wheel type and style are free, providing wheel meets or exceeds factory safety specifications.
D. One inch wider than originally supplied wheel which fits inside the stock body without rubbing and without modification exceeding “rolling” or “grinding” of the outer fender lip is allowed. Spacers are permitted.
4/2009
4. Brakes
A. Brake pad material and stainless brake lines are free.
B. Brake calipers and rotors must be as delivered by the factory.
C. Ducting of air to rotors is allowed.
D. Removal of dust shields (backing plates) is allowed.
E. Brake fluid is free.
F. Master Cylinders must be as supplied stock by the factory.
G. Hand brake components may be removed.
5. Transmission
A. Ratios of ring and pinion and individual gear sets must be stock.
B. Only stock limited slip differentials (LSDs) No locked differentials will be permitted.
C. Modification to, or substitution of, the shifter mechanism which reduces the range of motion is allowed.
D. Axels must remain stock.
6. Body/Chassis/Interior
A. Removal or substitution of components, other than those specifically indicated below, is not allowed.
B. Chassis/body, must be the same material and configuration as supplied by the factory. Sheet metal modifications in the spare tire compartment as required for installation of a fuel cell are allowed. A Fuel Cell is not required but highly recommended
C. Seats are free providing minimum weight [TBA] of vehicle is met. Any ballast to meet weight must be placed in a ballast box and be securely bolted to the chassis in the driving compartment only.
D. Steering wheels and shift ***** are free.
E. Only Series Spec front spliters and rear spoilers are allowed [TBA]
F. Modifications to the underside of the vehicle for the purpose of improving aerodynamics are not allowed.
G. All interior panels may be removed except main dash panel. Dash may be modified for roll cage installation only. Additional gauges may be added but the stock dash gauges must be retained
H. Headliners may be removed for installation of roll cages.
I. Airbags may be removed.
J. All carpeting may be removed. Sound-deadening and heat shield material may be removed.
K. Radio/PCM components and climate control system may be removed. Center lower dash may be modified with a panel of appropriate material or removed. Center console may be removed.
4/2009
1. Engine
2. Suspension
3. Tires and Wheels
4/2009
4. Brakes
5. Transmission
4/2009
#50
Below is how the cars will be set-up when delivered;
New 2009 Cayman or Cayman"S" with factory LSD 6 speed transmission
All the cars for the HSR "Cayman Interseries Championship" will come with the following equipment as standard spec installed.
Full Roll Cage
On-board fire system
Race seat and brackets
Harness
Kill switch
Window net
Spec "DOT" Slick type race tires
Spec 2 way adjustable coil over race shocks,springs,hats
Race brake pads and stainless lines with race fluid
All non essential parts removed as per rules
Competition alignment, corner weight and ride heights set
Track tested, dynoed and includes all labor
Full Roll Cage
Harness
Kill switch
Window net
#54
Full Roll Cage
Harness
Kill switch
Window net
Pricing target is $53k for the Cayman and $64k for the "S"
Full Roll Cage
Harness
Kill switch
Window net
#55
#59
can someone show me what the hippie livery looks like?
#60
