More info RA-1 vs. R888
Old 03-18-2009 | 08:10 PM
mglobe's Avatar
mglobe
The Penguin King
Running the 888's at 38/39 front/rear seems to work best for me in my 996
Old 03-18-2009 | 08:20 PM
mark kibort's Avatar
mark kibort
I forgot to check pressures for my first practice at Thunderhill in january, and found 45psi hot! actually, the car wasnt that bad. . These were RA1s, so I certainly wouldnt have a hard time with testing out some higher pressures with the R888s.
mk
Originally Posted by M758
Jim that is old news now. I am running arund 40 psi hot in the R888 as are all the fast guys. I did try as hgh as 48 psi hot and it was not horrible, but as I lowered the pressures a couple psi the tires got better. I have settled around 40 right now.
Old 03-18-2009 | 09:11 PM
todinlaw's Avatar
todinlaw
I thought I would post this becuase, the RA-1 is now extinct, can't find them as far as I know. So we better figure out the R888. I have read that they orginally recommended a high hot pressure reading then lowered it, everyone is searching, Like others I am going to try and do this as scientific as i can with tire, pressure, temps, and lap times with my traqmate. Somebody need to get there hands on a Toyo engineer at the track on some race weekend and pick there brain about how they designed it to operate.
Old 03-18-2009 | 10:45 PM
IcemanG17's Avatar
IcemanG17
When I tried my brand new R888's in January....the hot pressures coming off track were around 40....I ended up settling it down to 38 front and about 37 rear....the handling felt MUCH better than the RA1's I had before, but they were pretty worn....
Old 03-18-2009 | 11:35 PM
savowood's Avatar
savowood
I had settled on 38 all around. I may try to get them up to mid-40s next time I'm out and see what happens. With any luck, that'll be next Friday.
-Michael
Old 03-19-2009 | 08:36 AM
bb993tt's Avatar
bb993tt
I used these for two seasons in the UK. Took the advice of my tech and used the same pressures he recommended for his GT3 customers - 34F/38R hot. Given the weight of my porker that seemed to work well.
Quick Reply: More info RA-1 vs. R888
