Hoosiers R6s........heat cycles......
How many heat cycles do you get out of a new set?
How many heat cycles before the "sweet spot" is reached?
How many heat cycles does the "sweet spot" last?
Thanks......
Thanks......
Like Deep UV after 7 beers: DEPENDS
Professional Racing and Driving Coach
Paulo, have you announced that your racing or not? I tend to remember you had a date you were going to address your public, but don't know if that has passed or not.
Cycles before cording: my last set I got 41 cycles out of one rear, 28 out of the other. 1 fronts went at 21, the other is still going after 50+. The tires were flipped close to optimally.
Sweet spot: for my DE applications, they ran pretty fast up until they corded. The real race guys will have better info on the sweet spot.
-td
but to quote Professor Helmüt Tester
"More racing, less talking......."
Now, do you have an answer for the OP?
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
It's such a hard question to answer because there are so many variables. Like everyone before me said, 'IT DEPENDS".
I have a question for you: How much would it cost for a root canal for an 8 year old vs. a tooth extraction with spacer insert?
No one can answer this EXACTLY for you. Several reasons:
1) How long are the heat cycles?
2) How much grip feel before YOU think they're done?
3) Do you plan on scuffing them and then putting them up for a couple of days before running them?
4) How hard do YOU push them?
5) Are you going to flat spot them![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I'm always amazed at how high of a number some people report they get regarding heat cycles. As for the "Sweet" spot.... I would say, for me, optimal handling would be after I scuff them and put them away for a couple of days, then my first session with them on about my 4th lap. They'll never be better..... Some people will take fewer laps (like 2-3) to get them perfect but for the average DE/beginning Club Racer, generally, 6 laps. I read where Patrick Long said his tires had optimal grip on the 2nd lap....
I've also been into my 5th straight hour on a set (one heat cycle in an endurance race) and thought that they were awesome.
I spend a lot of money on tires. Plan on spending a lot for tires.
Pedro, thanks for the response.......
I was just wondering what to expect from my first set of R6s.......
That is what I will be using in my first CR......
Guys that I know who are really fast seem to agree that the sweet spot is the 1st or 2nd heat cycle and they have serious drop off in speed after 7-9 heat cycles.
It depends on a lot of the driver. If you aren't capable of driving to the tire's limit consistently, you may not feel a big difference between the first heat cycle and the 30th.
My plan for each race weekend is to put stickers on for quali and run 3-4 laps. Run them in a sprint or two and an enduro. The next race, practice with these and repeat the cycle for the next race. Thus I plan for one set per race weekend. With T&T days and an occasional DE this can work out pretty well and you can stay competetive.
Now in reality, I have a couple of issues: I spin so much I tend to flatspot the tires. I dont have LSD so I smoke the rears at tight tracks. Thus I average 1 1/2 sets per weekend.
