Traqmate and Aiptek HD
If your media files are in the same folder as where you had RaceRender save the .RRP project file (or they're in a subfolder of it), it should use relative paths and work automatically as long as you maintain that relationship on the recipient computer. But if your media files were some place like C:\Videos and your .RRP file was saved in a completely different location like C:\Documents and Settings\SomeUser\My Documents, then it's not going to find those media files on the recipient computer unless they were put into a folder with the same name and path as the original computer. But that's not a big deal... If that happens, it will display a message for every file that it can't find when you open the project, but it will not remove them from the project. All you should need to do is go into the Settings screen for each one that it couldn't find, click on the "Change File Settings" button, and tell it where to find the media file on that computer.
This sounds simple enough, but keep in mind that you are dealing with the computer challenged. The .RRP files are indeed saved on my computer in a C:\Documents and Settings\... file. When the email attachment reaches the other computer it will not open or play and does not give the option to "Change File Settings". RaceRender has been installed on the other computer. It must be something very simple that I am missing and I appreciate your patience.
