Dilemma......
#31
it is just that I haven't used Hoosiers yet.....
Yes, short gears......
#32
As far the short gears, I might be wrong (what do I know?) anyway my mechanic will go thru the car according to the CR rules and regulations and classify it accordingly......
#33
I skipped 3 pages. Ronnie is a good driver but my personal opinion is he has issues with authority (and maybe height issues too!). Let the fact go that he was fast in your car and move on. Sit down and spend an hour listening to him tell you which way the world turns then draw your own conclusions. I ordered the clams... If you think that car will run in a GT class and be competitive you may as well start drinking now. I sold my 2500LB 300HP 930 because I knew it wouldn't be...
#34
But what is all this GT talk? The car was in E at his time, nothing was changed, and now it is GT class?
I just don't get it........(but then what else is new?)
#36
Your car is a F Stock car
#37
Paolo, read the rule book, if your car has short gears, then it is not a legal transmission for either stock or prepared classes, regardless of where Ronnie ran the car at the time. That means you will end up running in the GT Classes.
The car is at least Prepared E (stock F) with the wing, big brakes, and chip.
Also, Prepared E and stock F are not the same. Prepared E is a D class car that has been prepared. At least, that's my understanding when I look at clubregistration.net to see who else is in my class.
#38
Also, consider effects on gearing with different sidewall and rim heights. Some are running those sizes on 15" rims and get great pull out of corners due to the shorter effective ratio.
#39
sorry for the confusion.......
(for a second I thought about selling the car and going SM)
Anyway, the original tire set up question is still on the table........
Thanks for the inputs so far.....
#42
Moderator
Back to your original question... It's my understanding that "wider tires" does not always mean more grip and thus quicker lap times. Depends on the weight of the car and how much heat you can get into the tires. When I had my 964 I was asking the right people about wider tires and they kept coming back to what I outlined above. Could be that 225/245 was the sweet spot for your car and the particular tires being run. With improved tire technology, it might be that slightly wider might prove to be the "new" sweet spot. You might have to ask around (people with similar car), experiment, etc.
#44
NASA Racer
Paolo, to put that time in perspective - last year Bill Richter ran a 1:01.1 in a D car running 245/275. That's two classes below your car. Setup is about what you make of it. His time is fast, but doesn't mean it couldn't be faster with another driver and setup to suit his style.
I'd run what you've got. Then use DE's to experiment with setup. Cups and saucers would be the perfect venue. If Gary goes, you could borrow a set of his
BTW, there are guys who are very fast and win races who are running 15 inch wheels with very skinny tires.
#45
Sean, this will be my first rookie race. My main goal is to finish accident free......
I guess I really should not worry about minutia......
BTW, there will be another set of black CCW with mounted R6s at LRP this year, kind of like the ones in your and Gary's avatar.......
