R3 questions
So, R3 question.... How well will it work on stock 3-point belts with airbag? How much protection will I get from side/offset/rear impact?
Save your money.
Also, if I get racing seats, does it mean the effectiveness of airbag or the benefit of airbag will be diminished?
I have been using the R3 for about 5 years now. I do not use the "pad" in any of the seats.
I tried the the "pad" and I found that uncomfortable and not needed in my Recaro and Sparco seats.
So I guess I'm a "naked" R3 user. I suggest you guys try it if you are having issues. I can not even tell its there.
Super Moderator
Needs More Cowbell
Needs More Cowbell
It certainly can't hurt, although you need to deal with the egress issue.
No.
Someone should put together a slippery slope progression list. Without giving the subject an ounce of thought, it probably goes something like this:
1. Helmet
2. Harness w/shoulder belts (4-point to start)
3. Head and neck restraint (if it connects to the belts)
4. Seat
6. 6 point harness
1. Helmet
4. Seat
6. 6 point harness
