Pinata vs SBox
#31
i did some comparison.
equal driver, i think BSR is slight faster
miata is MUCH MUCH cheaper.
but you be in SCCA/NASA not PCA if that matters to you.
a LOT more rubbing in SM.
bigger grid size in SM
i know ppl in CA that races both, so hey for the price of your TT, you can have both SM and BSR and a tow vehicle ;-)
i am building a BSR as we speak
Agreed with all; also depends on track too as to which are faster and what the set-up is (namely tires). At Laguna, the front runners in Spec Boxsters were running 1:45s; the Skip Barber front-runner MX-5s (that are much heavier than Spec Miatas and run on street tires) run 1:49s, with the instructors turning 1:48s. Spec Miatas are probably 1-2 seconds faster than the MX-5s due to tires and lighter weight. At Road America, the front runner Spec Boxsters ran 2:43s, while SB MX-5s run 2:51s (again, heavier cars than Spec Miatas and running on BF Goodrich street tires), with Spec Miatas probably in the 2:45-46s.
Then again, ultra-fast John Gordon can pull off 1:33s at Willow in his Spec Boxster, faster than GT-3s running at the same event by more than five seconds, and just a few ticks slower than my heavily modified 996 GT-3 driven by Cort Wagner and Craig Stanton on the same track (and all GT-3s running on MPSCs).
The Miata is definitely cheaper to run than a Spec Boxster; then again, the Spec Boxster is massively cheaper than running a Cup.
John - glad to see you are joining the Spec Boxster route - they are great fun and very popular (in POC) at least in the West!
#32
GT3 player par excellence
