New drilled rotor break in procedure??
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
^huh?
I'm going to just file down the Blacks if they need it and put them on.
Well it's not so much the bedding in of the pads, it's the rotors that I'm asking about. I too also liked the PF Cs and will probably go back to them after these Blacks wear out but I'm worried that if I put the new rotors on with these fairly worn Blacks, that I might be doing some harm to the rotor as they are not flat or even any more.
Is this concern warranted?
You're over analyzing it...
Still plays with cars.
Use your old pads on the new rotors. Pad transfer will work better which is why pagid and stop tech suggest doing it That way. The worn pads will not cause a problem and will wear to a flat surface matching the rotors. Or, do as suggested above, and go with PFC's.
Best,
Best,
We'll just file any obvious irregularities and go with old. Makes you wonder what you get on a new car though. You assume that all new cars, high performance too, have new rotors and pads. S'pose they don't care if you wear out components early?
