*Video* One lap of PBIR in a Daytona Prototype
I am a MoTeC dealer...
It was made using the i2Pro VideoGen feature we developed with MoTeC last year. Uses the VSM & GPS options, any camera/recorder, and is all driven from i2Pro. I've been working with Richard B, Allan H, and the devel team in Melbourne for a few years now.
The whole facility looks to be really nice when it is finished and they even have plans for parking for big events. I think they could easily hold a reasonable event there in a year or two.
TO answer a couple more things, the Cup was an 08 IMSA Cup. It runs the same line as the DP except I was drifting out a bit further mid corner in it through the 180's. The DP rotates more consistently through the corner. My impression of the Cup is that you have to kind of grab it by the back of the neck and throw it around a bit. You cary some brake to apex kepping it almost out of shape and then when you give a bit of throttle it stands right back up for you and then you can feed more in to go back to slight oversteer. Then again I'm not too experienced in a Cup car. As to line though, it still means the cup would like the straighter narrower entry with a narrower exit. The big difference between the cars is in braking. The DP drives like a typical downforce car with heavy initial brake and steady progressive easing of the brake. The cup is a flatter brake pressure profile. Unfortunately I don't have the Motec file from the cup or I would post it. I have the DP file but I am not sure if I can post it. I suppose I could find out though.
As to the audio, I'm sure your right. Its's probably just something set wrong. It may be on low qual to get a 24H on a card. I mentioned it to the data guy and he said he'd check it next time.
Peter you getting all this??!! I am counting on you to give us all the lowdown on the line at the January Instructor school. I can see it now 100 or so Instructors out there driving around BLIND!!!!!
I have to wonder has there ever been an Instructor school where so few could say "Yeah put the car there!!"
Yeah, I'm getting it.
I spent the day there again yesterday and will probably do another day before the Instructor Weekend. Most of my time there yesterday was in a Radical which, as much as I hate to say it, makes my 911 feel like a pig on roller skates. The line is a bit different too.
As I said earlier, I think the DP line is a great line. It will likely be a bit aggressive in a couple of places for some people relative to braking into the apex but it is definitely a line to strive for.
The good news is that the line isn't nearly as green as the last time you and I were there. A lot more grip now.
Good to hear on the grip thing it was a bit greasy on that first day
Do the turns have actual names yet? Is the kink T1 & T2? It seems like he was referring to what used to be T2 as T4. What is the 180 at the end of the back straight called, and I noticed he was double apexing it like T17 at Sebring.
That doesn't surprise me.
We need to organize a lead follow for the morning on Saturday.
Check your e-mail for my track map with numbers.
