Any heard about the new Mobil1 racing oil?
that's suppose to be available in the Spring of 2009?
Much more anti wear additives than standard oil and much lower viscosities ...
http://www.mobil1.com/USA-English/Mo...cing_Oils.aspx
"I've been using Mobil 1 15W-50 in my race car. How are these new oils better/different?
Mobil 1 15W-50 is a higher viscosity oil that delivers a thick oil film for protection of high performance engines. While Mobil 1 15W-50 can be used and is recommended for both street and track use, the new Mobil 1 Racing oils are only recommended for use in race engines at the track. Mobil 1 Racing 0W-30 and 0W-20 are lower viscosity oils designed to increase power output versus higher viscosity oils. Most importantly, Mobil 1 Racing oils are formulated with anti-wear (Zinc/Phosphorus) chemistries at twice the level of automotive street oils to protect race engines including high loaded flat tappet designs used in the NASCAR series."
Super Moderator
Needs More Cowbell
Needs More Cowbell
As much as I try and avoid all threads pertaining to oil viscosity (to put it another way...I'd much rather go in for a root canal, without novacaine, performed by an epileptic dentist who just discovered I have been sleeping with his wife and daughter)...... but why do I want 0W in a race car?
it is only a 0 weight at startup, 30 wt. at operating temp. This may be a good oil to mix in with other M1 offerings to beef up the additive package. 911 engines need a higher HTHS...It needs to be at least 3.4. I wonder what this new oil has.
If you are thinking about running in a street car with Cat's it may damage them see below from the link above
Automotive street use oils that meet the latest industry standards are required to have a lower level of Zinc and Phosphorus anti-wear chemistries than oils formulated years ago. The latest automotive street use engine oils are designed to be compatible with emission control equipment. Mobil 1 Racing oils are formulated with anti-wear (Zinc/Phosphorus) chemistries at twice the level of automotive street oils to provide enhanced protection of highly loaded valve train systems found in some race engines. Based on the high level of anti-wear chemistries, Mobil 1 Racing oils are not recommended for street use.
Dont do it! (at least not if you are doing any track use) Amsoil racing oil is probably the best stuff out there (along with redline). amsoil now has added zinc in their racing oil.
Basic Site Sponsor
Basic Site Sponsor
If is purely a racing oil, why bother with a multi-weight? I don't see the point, especially if the operating viscosity is down around 20 or 30 weight. I'll stick to my Amsoil, thank you very much.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
I'm certainly not an expert but my understanding is that most pro teams in various series from NASCAR to F1 run a very low viscosity weight oil...They probably know more than we do...
The big complaint as far as I understand it is the lower additives package that has been formulated to maximize mileage and minimize emissions. This seems to address that.
Basic Site Sponsor
Basic Site Sponsor
For our usage, longevity is paramount and so once again, we cannot look at what the top pros do and conclude that we should be doing like-wise.
The issue I see is running a thin oil is great for power. Thinner the oil the less pumping losses. So maybe 1-2 more hp. However for us club guys (especially 944) that could mean extra wear during hot high load running. Fine if you rebuilt every 4-5 races. Not so good it you want to rebuild every 4-5 years.
EDIT... Dang Larry beat me too it.
