A pass without a signal.......(G version)
#76
#78
In Rennsport you'd get a black flag end your session and be prevented from moving to black for another season.
#79
The Penguin King
It has been done several times, with Ghetto Racer being the most recent that I am aware of. If it doesn't happen in this case, I suggest that everyone on the Racing Forum now put BostonDMD on "ignore"!
#82
Paolo, you never mention whether the pass resulted in you winning the DE ? If you ended up winning.... F him. If not it just wasn't worth breaking the rules.
#83
I missed the video but if you passed without a signal you sir are a LOOOOSER. You are to play by the rules or pick up your marbles and go home. Come and play another day.
#86
Just go to a DE where passing is allow anywhere with caution. I know many guys that run in these groups all goes well. Personally I think getting stuck behind a slower that won't give a passing signal creates a more dangerious situation that just taking the bastard in safe clear spot.
Then again I don't do many DE's anymore. That is probably a reason why.
... Edit.... I guess I came late to this party... Oh well. I still think some of you guys get at little too uptight about passing rules. If you are experienced you should be able pass on straight without a pass in in a corner with a pass. If you can't handle that stay in the lower groups. I think that not allow in open passing in the upper groups is dis-service to those drivers and hold them back.
#89
....................... If you are experienced you should be able pass on straight without a pass in in a corner with a pass. If you can't handle that stay in the lower groups. I think that not allow in open passing in the upper groups is dis-service to those drivers and hold them back.
If you sign up for a set of rules, you follow them...or get out. If you are looking for a different set of rules, go elsewhere. Simple.
Signing up for an event, then saying you don't like the rules, makes a person sound rather stupid.
#90
