Do Pagid Blacks (RS14) groove your rotors?
#31
So you guys prefer PF97's over RS29 Yellow's? I have used both...PF97's and now on RS29 Yellows.
#32
I have a lot of cracking with the blacks. This is the second set of OEM discs that are cracked around the drilled holes with the Pagid Blacks. All in less than 6 track days and a full width of pads...
#34
I found the PF97's to have more inital bite over the RS29 Yellows. But I got a lot of heat transfer to the Caliper with the PF97's and they turned my red calipers a dark maroon color. The RS29 Yellows have never done this.
#35
I used Hawk Blue (HT-10) look at my fronts, grooved as all hell. Plus the Sh*tty Zimmerman rotors rust in the center and the cross drills cracked!!
I just ordered OEM Rotors today and I'm in the air on the pads this go round.
#36
NASA Racer
PFC97's
best setup I've had to date. I've tried every combo possible of cryo, slotted, drilled, oem, powerslot and on and on
#39
[QUOTE=007DT;5597670]I used Hawk Blue (HT-10) .....................QUOTE]
The Hawk Blue compound track pads are 9012s...Hawk refers to them as Blue 9012. The HT-10s are a higher heat range Hawk pad, and are actually black when new.
I find the HT-10s last longer and are more rotor friendly than the Blue 9012s.
