Top End Rebuild at High Marques in Morristown, NJNJ
An '83 SC I'm looking at had a top end rebuild at this place in 2002. This job included replacing several broken head studs that had to be machined out of the case. This was about 30K miles ago . Is this a quality shop with a good reputation for this kind of top end work? Feel free to PM me if you'd prefer.
Thanks,
Mike
Thanks,
Mike
This shop is no longer in business. The head mechanic passed away a few weeks ago. PM me and I will put you in touch with the former owner. He is a good honest guy. He will tell you what he knows.
High Marques is not out of business. John Voght sells high end cars upstairs and rents out the shop space down stairs to a repair shop and while it is possible that the current tennent has passed away (although I haven't heard) several shops have used that space over the past few years. Bull can give you better details
The tenant in the space now is Shade Tree Garage which recently moved in from the other side of Morristown.
Al P, Minoclan, Mike S,
As a employee of High Marques Motor Werks, Owner of Elite Motor Werks I can give you some insight to this scenario. Minoclan is correct High Marques Motorwerks is NO LONGER in business in the state of NJ as that company (it may have been dragged thru to another state but not in NJ) This job was done in High Marques Motorwerks, in 2002 it is unclear to me who did the work. If it was done by my former partner (who has passed away) did the upper end work I have great faith in his ability as he was a factory Unit repair technician (this means the guy who under older dealership ways of doing business got the most expensive and complete level of training of almost anyone @ the dealership) Most of the people on this list will scoff @ the idea of a factory tech being well trained, but believe me that when I tell you this guy has forgotten more than most people learn I am not kidding you. Anyway to the point Minoclan is correct and the car should be in good shape Mike S if you have any questions feel free to PM and let me know what your questions are as I have potentially laid eyes on this car and can recall history on it.
Colin Miller
Colin Miller
Edit: Hi Colin. Didn't see your post prior to posting below:
Anyway, the shop that rented space from High Marques Motor Cars in 2002 is long out of business. As reported above, there have been two other shops as tenants since then. The current tenant, Shade Tree Garage, is excellent and will be there for the long term, as they were in there previous location for 30years (I wrote and negotiated the lease).
I suspect that the work done 6 years and 30k miles ago was fairly sound if the engine passes a PPI now.
Thanks all for the helpful info. I am still waiting to get a copy off the receipt for the work done.
Bull/Bob W.,
What were you thinking re engine PPI?
Would you then be recommending a leakdown test? My initial thought was that if I rec'd very positive feedback on who did the work and I found out from the receipt that job was properly done/thorough (all studs replaced in steel, etc...). I should be all set. In essence, if I heard that the mechanic was the Dan Jacobs of NE NJ, I'd likely get real comfortable. Especially so I get essentially no smoke on startup from a cold start with the car sitting several days (after a hot run) + I hear that oil consumption is decent (1 qt every 3000 miles). I know the later is really hard to determine or put my faith in unless the seller is honest, observant, and fastidious.
TIA for any advice!![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Mike
TIA for any advice!
Mike
Colin Miller
Colin Miller
Mike
Bull/Bob W.,
Mike
Bull/Bob W.,
TIA for any advice!
Mike
Bull...thanks for the sage advice. I will add a compression and leakdown to the professional PPI. If something negative is found, we can dicker on a price adjustment or I can walk away.
Mike
Mike
