Anyone going to the ALMS race at Lime Rock
#46
Sorry Bull, but just like driving on concrete doesn't mean someone knows spit about designing, producing, testing, and performance of the product, the same goes for bitumen based pavements. Let's see if O&G Industries, the producer of the pavement, has a clue.. Am I saying the pavement won't be flying into the grass outside of Big Bend? Nope.. I have no prediction either way..
#47
This wasn't a quick scarification and thintopping, though I understand what you are saying (Summit is a prime example of how NOT to do it). It looks to me that the only "repave" was in areas that had a solid sub-base, i.e. the main straight and the bulk of no-name. I wasn't there and can only go by pictures but it seems that sub-grade work was done at the end of the main straight through big bend, the end of no-name through the uphill, all of west bend and the downhill. The most important part of ANY pavement, whether it be concrete or asphalt, is the sub-grade. Mr. Barber has mentioned that very fact, though slightly clouded in rhetoric, in past releases. I'll add that even IF they ripped up the whole track and put the most pristine subgrade material in there available it still would be no guarantee of future stability. IMHO the whole place needs a redesign of slope and drainage as a first step, THEN worry about the track surface... but no one asked me..
#51
Owns the Streets
Needs Camber
Needs Camber
Never thought about drainage at LR till a few years ago when the bathrooms were closed after it had rained buckets the days before.
Nothing like capturing all that water from the hill and putting it on the run-off area for the left hander.
The mini-lake did make all the racers very very tepid going through turn 2. Has anyone ever tried racing slicks on that surface water.
I thought I saw a picture of tunneling just after turn 2. Maybe it was wishful thinking that they sunk drainage pipes to take that water away from the inside run-off area.
#52
This wasn't a quick scarification and thintopping, though I understand what you are saying (Summit is a prime example of how NOT to do it). It looks to me that the only "repave" was in areas that had a solid sub-base, i.e. the main straight and the bulk of no-name. I wasn't there and can only go by pictures but it seems that sub-grade work was done at the end of the main straight through big bend, the end of no-name through the uphill, all of west bend and the downhill. The most important part of ANY pavement, whether it be concrete or asphalt, is the sub-grade. Mr. Barber has mentioned that very fact, though slightly clouded in rhetoric, in past releases. I'll add that even IF they ripped up the whole track and put the most pristine subgrade material in there available it still would be no guarantee of future stability. IMHO the whole place needs a redesign of slope and drainage as a first step, THEN worry about the track surface... but no one asked me.. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
