AIM GPS
#31
Good to hear from you Rick.
#33
Member - times 3
Member - times 3
The GPS adds calculated lateral and longitudinal g's. The MXL only has a lateral accelerometer. The GPS allows you to review your path on the track. You can export the path as a google earth kml file, and you can check out our line BUT there may be some offset, and I don't think you can adjust it away. (Mostly a gimic to make up for the fact that they don't let you define track outlines in their software.)
GPS speed is likely more accurate than wheel speed or ECU speed, but there may be some lag. GPS also provides calculated items like gyro (turn rate, but not really raw rate), heading and slope.
Worth the cost IMHO.
#35
The install is the killer. No, I'm not buying it from Joe (we've discussed it offline). I need whoever installs it to support it, and they are not likely in these parts unless I buy it from them, too. My guy is going to charge about $3400 installed before GPS, with the basic sensors. The $4k was before he discounted it.
#37
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
As a consolation prize Ben mentioned something about getting to drive his car though......He just wouldn't put it in writing. Hmm...
#38
#39
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Ben's installer is setting him up and a local data guru is involved so it's a deal that I agreed with him was tough to beat.
#41
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Depends on the level that you want. You can get a non GPS system with fewer channels for 999.00 and the driver sensors would be the same 400.
Roughly 3000 for the systems that Ben wil have and Gary has in their cars.
They have the MXL Pista dash, GPS, extra sensors, patch cables. Dash retails for 2K, GPS is 600 and the extra sensors are ball park 400.
The install takes some work just because you have to fabricate mounts for a few of the sensors. I tell people to budget 5-10 hours for a shop to do it depending on the car and the shops expertise.
#42
My car is torn apart as we speak... Should be back next week. Can't wait.
TIA
#43
#44
Antenna wire runs into trunk and magnetic antenna is on the cowl a few inches from my right fender seam, works great there. My system is wired to go on with the ignition, though it would be better in some ways to only turn it on when you want it to record. Every time I start the car I get a new data file, even if it's only to back it out of the trailer..
#45
I think I might wire the AIM system to the fog light switch, so I can manually turn it on and off.
