Video Question: How to reduce wind noise?
I have a Panasonic HDC-SD5PP in car video camera that picks up a lot of wind noise. Any expert suggestions as to how I could reduce/eliminate wind noise so as to hear sounds that are relevant?
Thanks...
Thanks...
I use a Sony handcam (DCR-HC46) with no external mic so I tape over the camera mic. There's a little wind noise, but not too bad: http://www.youtube.com/watch?v=-Nwk9kpu148
If you camera accepts a remote mike, that is your best bet. The normal mounting point puts the camera and its built in mike right in the wind stream.
You can mount the remote mike just about anywhere that is not directly in the wind stream. Sadly, I have a ZR830 which doesn't accept a remote mike. I glued a big block of foam to the built in mike. That helps a bit.
Roll up the windows.
Brian great idea. I am tired of making little paper towel wind screens that are taped over the mic (which works). A band-aid makes sense. Now can we have a thread on what brand of band-aids work best as a wind screen.
