PCA Club Racing adds Spec Boxster Class
#31
That's my conclusion too. I'm installing a roof net and window net before my next race to eliminate the arm restraints and for general safety. I want to run without the roof so the roof net would be mandatory...
#32
Ironman 140.6
That & it's much cooler. First thing I noticed in the Boxster is how damn hot it gets inside compared to the Cup. The curve @ the back of the window & the smaller opening must really impede airflow into the cockpit. Plus you have a hot box sitting right behind you![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
#39
I'm in....
No wind tunnel, but I have noticed that high speed stability in fast corners (say Bishops Bend - Sebring) feel better with the top on. I have a fiberglass top with lexan rear window. I believe this helps airflow over the top and down over the rear deck and wing.
#42
there MAY be less lift, but there is certainly much more drag.
#43
I'm in....
drag is lower with a closed top. the turbulence caused by the air flowing over the top of the windscreen and into the cabin is significant. anyone who's taken a boxster on a long trip knows that the gas mileage improves about 15% with the top up.
#44
Ironman 140.6
