PCA Club Racing adds Spec Boxster Class
Thanks,always need to expand! Please get some info out so some of us less clued in racers can learn about spec boxster !
I was reading the spec rules and they were specific about the oil sump pan can only be the Brey Krause oil pan. Didn't someone recently modify a x51 pan where the baffle flaps were modified to metal instead of the flexible plastic. Is this a possible change. I am not totally up on the x51 oil fix but I thought it required a little bit more fabrication to get it to work. Is the extra fabrication a no-no in boxster spec racing.
Maybe this is a non issue because the boxster spec rules calls for a 2.5L motor not a 3.4L. Or does it not matter.
It also looks like they have edited the rules. PSS10's are an option now! But I bet you can get a smoking deal on PSS9's now.
GT3 player par excellence
Wow sounds like a "stock" class
