What are G50 trans temps you see?
For those who have G50 trans oil temp sensors, what temps do you see?
...please advise ballpark hp and if temp is with or without trans cooling.
On my RSR I see 200F after about 20 minutes of driving which is when my trans pump comes on. Without it, temps are over 260F. On my Turbo it would be 280 or so with an infared pyrometer after a 1 hour session.
My putt-putt car makes 300 hp at the flywheel. I have a G50/32. I've had two outings this spring since getting the sensors installed (with MoTeC data acquisition). On a cool day (air inlet temp of 70) about 200 F after 25 minutes. On a warm day (air inlet temp mid-90's) I saw 230 F after 30 minutes. I'll probably be adding a transmission cooler now.
