Damper adjustments vs spring rates?
Interesting topic! By no means any sort of guru, but the less bump damping for increased spring rate does make sense. In Larry's example above, a spring will overshoot equilibirium when subjected to an impact. But when comparing 2 springs with differing spring rates and subjected to the same impact, the spring with the lower rate will overshoot the equilibrium compression by more than the stiffer spring. The damper's job is to control this excess motion, the spring with less rate would require more from the damper to control the motion than the stiffer spring. So less bump for the stiffer spring rate.
I have no data to back this up, but makes sense to my engineering mind. Now if I could only really tell how this feels on the track, I might be able to do something with it...
Cheers!
Cheers!
Very nice and interesting data Geoffrey - thanks for posting it! I've always wondered how tuning shocks is done with data...
Mr. Excitement
Another simplistic way to put it. Spring rate and bump damping cannot exceed a value or the car body will move up. The key is to keep the body from changing ride height and to keep the tire on the pavement as it undulates. More spring = less bump or you exceed a set-point and the chassis moves before the suspension travel is used up. You need enough spring and bump to keep the wheel from hopping around like a basketball but not so much that the car does the hopping.
tip of the iceberg.
tip of the iceberg.
Lifetime Rennlist Member
You're too subtle for me, Mark! LOL No, I didn't notice that, I was just digging the description and the pretty graphs...
Basic Site Sponsor
Basic Site Sponsor
Thanks, Larry. That "overshoot" explanation is not something I have thought about. Wouldn't that be most prevalent in high-speed damping, though, and not low-speed, i.e, more applicable to running over berms or bumps than in smoother transitions like cornering and braking, which would primarily be low-speed damping? Are you running triple adjustables or double?
All I have ever heard from the easily accessible sources has indicated to me that stiffer springs require less damping in bump and more in droop.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
