toggle style circuit breakers -- anyone used them?
Was just looking into switches, fuses, breakers, etc for dash and came by these. Looks like nice way to elimnate need to have fuse/breaker and switch, and get in one package. ...anyone use them or have comments?
http://www.hrpworld.com/index.cfm?fo...action=product
Basic Site Sponsor
Basic Site Sponsor
Looks good to me. I am in the electrical contracting business and Siemens makes a good product. Just make certain that you fuse the main feeder to the switches, because unlike a sealed fusebox where the hot terminals are protected, if the "hot side" shorts, you will melt back to the battery.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
They look heavy...Depending on the number of circuits you need, there are intelligent power management systems available that are computer configured. They have a built in CAN interface so your ECU or dash logger can turn things on and off as well as simple grounded switches. This replaces all of the fueses and relays in a car.
Heavy? Not really (in my opinion for a club race car).
It really depends on your application. If you're just trying to power a coolsuit or a fan bypass switch, the individual switches are great. Some of the pre-made panels are good if you have a few circuits, and you can easily run an entire car off of one or two panels. The moroso panels are decent, not amazing quality but they work well and are easy to use. Paneltronics makes panels for boats, and they will make it to your needs and the quality is a step up from the moroso panel.
And, while the PCMs look to be really cool, seems like overkill for most applications (can any be had for sub 2k complete?)
Can you trust a system to replace a breaker or fuse? Are the wires protected in a hot to ground event if the system is compromised?
The wires are protected by a user configurable amperage fuse which can be set for a maximum threshold (of the wire), and will allow overvoltage for things like motor startup and other devices that may draw 4-5x the normal current when starting. The system IS designed to protect the wiring harness, not the devices themselves.
