Hewland
Let's say I've completely lost my mind and/or won the lottery and decided to put a sequential gear box in a 911 GT class car. Does Hewland make a transmission for rear engined cars? How hard is this to do?
"Yes" and "not hard, but not cheap".
Google Mid Valley Engineering, and get out your wallet. Maybe get a firm hold of your ankles at the same time.
I think Saenz used to/still does make something, too. Of course, in typical Saenz tradition, you have to take the brand new box apart, throw out all the bearings, re-clearance everything etc. before you can actually use it.
Sort of semi-related to that, what about keeping everything in the G-50 OEM except the synchros themselves? At $900-$1100 a pair new, I would think you could get some made, or modify some from another application off the shelf, to work, for a lot less money. Anyone ever tried this?
Guard Transmission has straight cut gears available to create a "crash box" out of a G50. Hewland did make a sequential gearbox for the Porsche 993 cars. Tony Callias knows about them.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If I was going to go the route of doing anything like that I'd first call Taylor Race Engineering. They are some serious gurus with Hewland and other racing transmissions.
http://www.taylor-race.com/
Wow, I didn't realize you GT guys went that far. Redesigning a tranny within the case to conform to the rules seems way out there for me.
I guess that's why I stick to the stock classes.
Good Luck!
Good Luck!
Holinger is the Aus company that makes a whole guts replacement for race 996 GT2/GT3 gearboxes that is sequential.
They replace eveything inside.
With the exchange rate the last time I checked the conversion parts were $20K not including the gearbox - several years ago they were only $14K.
The downer is that they custom make everything and it takes 3 months.
So if you are considering one you should really buy 2 full sets in case you need spares because according to Holinger you wont normally be able to get the parts during the season.
It is rated to handle 650 ft-lbs.
I did all the research before I ended up swapping to a cable shift race 996 GT2 gearbox.
I also checked in Ricardo and the like...
By the rules the case I believe must be a factory Porsche case so that limits the options.
I may try the Holinger upgrade next year we will see...
btw - Cory's suggestion is a good one. I could do it due to my torque...
Norm
Norm
