Tire wear with aggressive camber (question)
I am running -3.0 front and -2.5 rear camber on my car because it dramtically improves the handling, it also dramtically wears the inside edge of the tires.
Is there any way to get more even wear out of tires with camber this aggressive? The outer edges look untouched.
Do toe kits help this occurence, or is it a penalty of being able to turn better?
Drive faster/harder. By your description, you either have too much camber for the tire, or too much camber for the lateral acceleration you are able to carry through the corner ie not driving the car hard enough.
What kind of car is it? What tires?
996 TT on Sport Cups.
I did do a 400 mile mountain run on the tires as well, so the majority of the inner wear came at that time, but it was still pretty uneven. I just reversed the tires inside out so they wouldntv cord immediately.
I'm also running a bit of Toe in.
Though I'm doing Barber next and I would bet I get more out of the camber than I would at Road Atlanta.
I definitely need a pyrometer though.
Ideal camber for track setup is not even close to compatible with 400 mile street drives.
If you are doing a lot of street driving and a few track events, it might be worth getting yourself a camber gauge and leaning to set the camber for your track events and to reset it for street use.
As Mark said, tire temps are the most reliable diagnostic for optimal track setup.
I've gotten some argument on this, but I have fount a tiny bit of toe-out (1/8" total) up front, and a little more toe-in (3/16-1/4" total) in the rear is a great setup. It makes turn-in more immediate and carries well through the turns. It does make it a little skittish on the highway, but I am doing less street driving each year. This may not apply to later 911s - YMMV.
+1 on "You need a pyrometer".
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The toe wore the tires out like crazy and the camber didn't wear the inner edge too much.
I will buy a pyrometer in the next couple of weeks.
I was running toe in because it helped with braking, but I'm moving to toe out to help turning as that is a bigger concern. I'm going to keep -3 for barber since there are so many turns and it's not a high speed track, but when I go to VIR the following weekend, I may change to 2.8 or so.
Thanks for the input guys.
But while we are on the subject, I know it varies by tire, but what are safe temperature deltas for the pyrometer? And do you take the outside edge temp, inside edge temp and middle, or some other series of points to determine.
Is it possible to be within the operable temperature range and not get the desired handling affect or even wear? Or generally does the camber/tire wear and temperatures balance out? Meaning if I am running too hot on the inside edge, that means I'm not using all of the tire anyways during cornering so a decrease in camber wont significantly affect the handling but will even the tire wear?
Have you tried less adjustment with camber and more with sway bars? You may be able to get the handling you want at the track with easier to adjust sway bars. I would guess that anything over about a 1-1.5 degrees negative camber on the road and you are going to see unwanted tire wear. My .02
I know that street driving and track alignment dont mix, but I mentioned before that the tread wear was moderately uneven before, now its EXTREMELY uneven.
I am far from the Road Atlanta track mastah (only been there once, at last year's club race, and absolutely loved it, BTW), but if you're pushing in T1, maybe you have some other balance issues. That turn is fast; I like having some understeer so I can go in deeper and harder. If you've got a big a** H&R sway in the rear and a stock bar up front, it sounds like you love oversteer. Is there that much understeer with a 996TT? I've instructed a student in one and never noticed an excessive amount of push.
