Best R comp track tire for 2 driver car, most life?
I'm onto my 3rd set of R888's and I think they have just started to bring them into the US by now. They are seen as a superior tyre to the RA1 and I've found they get up to heat quickly but also offer a long life. When they have a bit of tread they're actually not bad in the wet either.
As time goes on we will change our approach or possibly my wife will drive the C2 and i will drive a different car. For now I am looking for better than street traction without spending thousands on tires in a season.
So far you guys gave me a lot of food for thought. Much appreciated and all in about 20 minutes of post time.
Ted wrote:
I corded my front Hoosiers last Nov. while running at Roebling Road with Ted. I borrowed his "spent" RA-1s for the three sessions on Sunday that we stayed for (I also had to raise the front end one full turn to get them not to rub because they were 944 offset), and proceeded to take another 4 seconds a lap off. I was still on the steep portion of the learning-the-track curve. My next set will be RA-1 or R888s.
FWIW, I normally get someone else's Hoosiers with 6-8 heat cycles and drive them until they are north of 40 heat cycles total. That is normally when they cord. My car is 2818 with me and 5/8 tank.
I shared a car with my son (different run groups) for 2/3 of last season. Got +50 heat cycles and have some life left. As stated not the fastest at that age but still OK for a slow guy like me. YMMV.
Define useless...people complain because the faster R-comps like the Hoosiers drop off a LOT more over their life than something like a Toyo which is more consistent. That said, I've seen some suggest that a Hoosier at it's slowest is still faster than a Toyo at it's fastest, even though the delta between fastest and slowest for each individual tire is much bigger on the Hoosier.
If the RA-1 seemed to get greasy after a run you may be running too much air in the tires. I have found that over 40psi hot and RA-1's get slick. I start around 32 to see 38-39 psi hot. (2600lbs 944 NA) I have heard that the R888 might heat up more than RA-1 and thus need lower starting pressures.
from what I've been hearing from people in my region, the R6 Hoosiers have a very good life cycle. I also think that the older models lasted longer than 8-10 heat cycles - that's 1 weekend.
Steve
Steve
My biggest concern is my wifes comfort and safety. She has learned a lot in a short time and I want the tire to be consistent over its life. She still has a lot to learn and i don't want to throw too much at her at once. If we go with Hossiers and they loose their grip over the first few events she will most likely find this unnerving. I think until she gets another year under her belt I would prefer to have a tire that gives her consistent feedback so she can focus on the other aspects of fast driving.
Hate to say I started this thread late and have to pick up my son. If you guys have any other comments I would appreciate hearing them an will comment back tomorrow.
Our lap times stay pretty consistent over the life of the tire. For us we go to a new set ot tires when the car doesn't like to turn.
Not saying the R6s are for you but they are faster than any other R compond out there.
Who told you to expect 10 HC's on a set of R6's??? I got a got solid 16 HC's (4 days with 4 run sessions a day) and then ran them a 5th day (4 more HC's) and could see my times were about 1 second slower (but plenty of life left in the tire). And this is running a GT3 with full suspension upgrades and pushed at 9-10/10th most of time. I also ran the Nitto NT01 and loved them! Got about 50HC's. It is true what they say about the NT01, you can run them until they cord. I was a couple seconds faster at VIR with the R6 over the NT01 but still a great tire. If you are sharing with your wife I would suggest either (a) get two sets of wheels and tires and swap between sessions (PITA!) or (b) go with NT01, RA1, R888 (all the same compound).
Anthony, I too have found that the R6s last far longer than the earlier Hoosiers, and most people who I hear talking about short life spans of Hoosiers have never experienced the R6s. The R6s are a very different tire from the earlier 03s,04s, etc. Anyway, I have seen more than 40 heat cycles from a set of R6s . They do drop off after the early cycles, but begin at a much better level than the other R compounds I have tried. I see about the same life out of them as i did from the MPSCs when I ran them.
I have never shared my car with another driver, so can't report on that type of usage.
[QUOTE=Bull;5019333]Anthony, I too have found that the R6s last far longer than the earlier Hoosiers, and most people who I hear talking about short life spans of Hoosiers have never experienced the R6s. The R6s are a very different tire from the earlier 03s,04s, etc. Anyway, I have seen more than 40 heat cycles from a set of R6s . They do drop off after the early cycles, but begin at a much better level than the other R compounds I have tried. I see about the same life out of them as i did from the MPSCs when I ran them.
+1
+1
with nearly 400hp, you might want a 275-295 width rear, rather than a 265 as you mentioned earlier, to help put the power down. 225-245 front. RA1/R888 seem to have the best "life" for an R comp, but that is a relative term. What do you think would be a "good" number of days/events? 8 days? 12 days? 4 events? Getting great life all comes down to suspension set up and driving style. Even with my modest SC, overdriven naturally so I could win the DE Championships
, I could just barely squeak out a 6 (2-day) event summer, with some AX mixed in, as a 1 driver car with RA-1s.
Keeping in mind your wife driving the car ( my wife drives also). Nitto or RA-1. Unless you plan to teach your wife how to really warm up a set of MPSCs, then forgetaboutit. She is not going to push enough to get grip on MPSCs and be frustrated (ask me how I know). The other problem is pressures. Your driving styles may be very different so optimum for you is going to as much as 3-4psi more than what she gets during a run session. One last tire I have seen two driver cars use is the Hankooks. I have no opinion on them, but they seem to be happy with the results.
On a 996, co-driven for some events by my dad and myself, he got over 50 HC's last season from a set of R6s and still no cords. If the car was co-driven by someone more capable than I, there might be more wear.
Oh yeah, and they survived the Pocono infield landing strip too...
