Traqmate Inputs using TraqData/TraqTach add-on (what have you added?)
#46
Nothing deceiving about that.
#47
Well, my DL-1 manual also instructs how to hook the various connectors... Haven't read any warning on Special electric Knowledge. In any case, I have try to make the instalation with an expert Porsche mechanic ( trained originally by Porsche). And about "getting help from my dealer" can only be obtained through the Forum as there is no DL-1 Dealer ( nor Traqmante ) in Spain...You solve your problems through a Forum.. Again, a bit frustrating..( You ask, they answer, clarify some misunderstandings, translate into spanish to my mechanic, back again to the forum...).
If this is not deceiving... after expending 1.000 $
Anyhow , I was just sharing my frustration. ..
I still do not know how to make the DL-1 together with the sensors...
#48
Have you thought about contacting the manufacturer of the DL-1 (Race Technologies)?
http://www.actdigital.com/Contact.htm
#49
I think everything works now, at least it does on the display unit. Have not gone over the data yet from last weekend at Sebring to see if there were any issues.
LVDell, what I tried to say (wrong hole/Seinfeld electrician) is that the manual clearly states not to put a High Voltage Source into a Digital output. Me on the other hand, after I started rewiring, then realized that I may have switched the wires. Just to make sure that I did indeed swith the wires, I turned on the ignition and stepped on the brake. That confirmed that I had indeed switched the wires
#50
LVDelll.- Thanks for your comments and help. Everything seems to be working now. The pin #9 works beautifully for the RPM. The rest works..now...?? Big mistery. After adding the RPM sensor all seems to work !!
Erik.- Thanks for your input and help.
#52
Looks like I'm coming to this late, but........
If you click Programs/Race Technology you should see a selection for Analysis and one for Monitor.
With your PC connected to the DL1 installed in the car, Monitor displays the data that the DL1 is seeing in real time. Being able to see the data without having to log it, download it, and run it in Analysis is really very helpful when getting things connected.
#53
APKhaos,
Thanks for the clue. As a mater of fact, I was aware of the Monitor function. I was scared of using it as I became "familiar" ( if this is the word that describes my relationship with the software ) with the "Analysis" program. I did not want to add a new variable ( my complete ignorance of how to use the "Monitor" program..
Thanks again,
Thanks again,
#54
APKhaos,
Thanks again,
Thanks again,
#55
Tony,
On a related question since you're the guru. I have the Chasecam, and the video plays just fine on my home computer using Windows Media Player, but I can't get it to play on my laptop that I take to the track with me. Does Trackvision program actually allow me to play the video ?
#56
TrackVision adds the data from the acquisition system onto the Chascam video, it's not designed for video playback, like say Quicktime is.
You need to get the "codecs" to play the MPEG-2 that Chasecam records on your laptop. You can find the info on the Chasecam forum.
#57
Thanks Tom,
My video now plays on my laptop, but no sound :-). I can download a MPEG-2 from Apple for $20, but I'm wondering if you have any experience with any editing software such as Sony Vegas. I'm just wondering if I spend the $20 with Apple, I will be able to at least cut and edit some of the video, or should I just spring for the $75.00, be able to edit and at the same time view my video's
#58
Sony Vegas might be the best sub-$100 PC video edit package around.
There are Mac packages that are better, but if you add the cost of all those black t shirts you'd need to buy to be a proper Mac user.....
