Racing belt question
I am in the process of making the decision as to what belts to put in my car. I have the roll bar and GT3 recaro seats. I am considering the Schroth Profi II 6H belts for the Hans application. I did a search on the list to pick up all discussions on this belt and came across post from 2006 that said that you could not use the profi 3-2 belt ( two inch shoulder belts) unless you were using a hans devise. I plan to get the device but I assume that you can you the two inch shoulder belts without it is this correct.
also a vender is proposing that I by the Schroth belt though Porsche which is more expensive then going to another vender. any thoughts about the Porsche Schroth belts, worth the extra price?
RL Technical Advisor
Hi:
As a long-time Schroth distributor and installer, I would tell you that the Profi HANS-specific belts should never, ever be used without the HANS in use in case (God forbid) you actually need them. Unless you commit to putting the HANS device on each & every time, I would get the Profi-II 6-pt setup.
IMHO,..the Porsche-sourced belts offer nothing more than the opportunity to say where you bought them,.....
I just picked up my new set of OMP 6pts and am very impressed with their quality. The features are top notch with clip-in ends, aluminum adjusters, beautiful lightweight camlock. Reasonably priced and top notch stuff.
A word to the wise, if you buy belts other than Schroth Profi II, with or without Hans shoulder belts, or the Porsche-labeled Schroth belts, make sure that the aluminum adjusters on the lap belts will clear the slots in your GT3 Recaro seats. Many of the adjusters are simply too large for the slots and your lap belt adjuster will be stuck on one side or the other of the slot. The Schroth Profi II work well and there are no clearance problems.
I purchased a set of Profii II-6 belts for both driver and passenger side of my car. Then I ADDED a set of Profi II-6HANS shoulder belts to the driver side as well. I can now use my HANS when I am driving and NOT when I am taking out a student and still have the proper belts on for the proper application.
Lifetime Rennlist Member
Mr. Excitement
2. Hooker may be the only mfgr to use mil spec webbing. The Air Force replaces theirs every 13 years. Very cost effective.
3. With the ratchet on the lap belt it will not loosen, ever. This why it is so popular for aerobatics, off road racing, off shore boat racing, monster truck and dirt circle track racing--and crash testing.
We test exclusively with Hooker.
Gregg Baker, P.E.
Isaac, LLC
Mr. Excitement
Thanks. I learns me something every day. The ratchet was the point that I am looking into further. sit down snug up and crank in "Crew chief pulled tight" without having a guy step on you and pull your belts.
I already had the Profi II-6 belts in the car that I installed last year (both sides). Then, about 2 or 3 months ago I purchased a new helmet and HANS device. When I did, I kept my old helmet which has my Chatterbox bolted onto it that I use for when I am instructing. When I take a student out in my car, I do not wear a HANS when I have the Chatterbox helmet b/c I do not have anchors installed on it nor would it be easy to move my head around easily when talking to a student when explaining the track, etc.. Unless, it is a "go fast" session where I don't talk to the student at that speed or x/10th level then I wear the HANS and tell them I am not going to talk but rather focus solely on driving.
The PROFI II-6 HANS shoulder belts (2 to 3) were available for purchase for about $180 IIRC. Iwent through HMS for that.
Mr. Excitement
Just an unasked for internet opinion which is worth 1/2 of a nigerian spam email. I would be inclined to put the chatterbox on the HANS helmet or HANS on the chatterbox helmet. You do not need eye contact to instruct a student in your car. Slow laps does not mean squat. 30 mph delta impact is 40 Gs or so. You would look real stupid getting you neck snapped after purchasing 3 sets of belts, 2 helments and one H&N.
