Who has set up their helmet for a Head-n-Neck Restraint?
I read all the scare-mongering, figured that if I broke my neck my wife would have my ***, and bought an R3. But getting the D-rings on my helmet might be a problem. You guys that have HNR's that connect to the helmet, did any of you have nonremovable helmet padding? If so, how did you screw these things into your helmet if you couldn't remove the padding?
I have a Arai GP-4K and near as I can tell the only padding that removes is the cheek pieces.
It is very easy. First glue the round "nut" to the washer using crazy glue gel to keep it from sliding around when you install it. Then carefully work a narrow putty knife up about 2" between the shell and the padding only where you drilled the mounting holes. Slide the nut/washer into the gap and screw in the D ring. Voila!
If you are really ****, you could use some hot glue to refasten the little bit of padding.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
And yes, I even used the hot glue gun to get the padding refastened to the inside shell.
Well, I'll let y'all in on a little secret. I bought my HANS at Hubbard-Downing when I was in Atlanta and had them install the anchors. They use a really thin metal strip (not unlike a putty knife blade) that has been notched to hold the nut (like an open end wrench or spanner for our friends across the pond). They put the nut in the notch and slide everything into place. Quite slick I thought.
Of course, you could always use a product that did not require a helmet connection...
"Heat bonded" = $5 glue gun to glue padding back after loosening it with a butter knife from kitchen drawer. I bet the wife has a glue gun and she might let you use it if she does not see you using the butter knife. You can lightly heat glue the nut to a regular open end wrench if you H&N does not come with one. pops right off after install
As Kurt alluded to above, ALL helmet padding is removable. They got it in there when they made the damn thing, DIDN'T THEY ? Butter knife/hacksaw blade/screw-driver/etc. will free the padding from the glue, and then just use a hot-glue gun to put it all back in place.
You might need four hands to do it, but it's simple to do (especially if you have four hands).
