Help with data acquisition please
#76
-Scott
#79
Thanks.
-Scott
#80
Scott,
One of my rigs is a G2X which is fitted with a couple of Racepak VNET sensors:
- 0-5V analog which is connected to the TPS for throttle position
- Digital event which is connected to the brake switch
- The mandatory Aux to VNEt cable which brings these and any other VNET sensors in the G2X.
These generic sensors run around $100 each, plus around $100 for the VNET cable.
No sensor required for RPM, of course.
It's a snap to set up. There's a short flash video clip using this setup HERE
#81
Thanks for the info.
One of the confusions I was having was do you need one $100 vnet cable for each sensor (ie, min $100 per sensor), or do you just need one vnet cable to add as many sensors as you want ($100 for as many sensors as you want)?
-Scott
-Scott
#82
Fortunately, its one Aux to VNET for all. The individual sensor connectors plug up in a piggy-back stack. The connector system is quite sophisticated, with o-ring moisture sealing and positive locks. Its a nice system.
#84
