F*^#@ Race seats
In Your Face, Ace
So I order a Sabelt Taurus XL to replace my Sparco Pro 2000 currently in the car. Once I get the seat and unbox it, I instantly realize it looks to be no bigger that what I have. So I take a few measurements and confirm what I thought. Not only is the seat no bigger than what I have but in fact in some spots it's smaller. Now I've paid shipping to me and must again pay shipping to return it. Plus, I really need the seat for next weekend and wanted to install over this weekend. ![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
So now, I've gotten a hold of some size charts (could not get one for Sabelt) and it appears the Sparco Evo 3 is the biggest seat I can find.
I'm just pissed because the Sabelt seat is advertised as (one of the largest in the industry" so I assumed it was.
Now I'm concerned for seat height. My Pro 2000 is bottom mounted and the Evo 3 is a side mount only. So now I am concerned the height might be to high once installed.
My Pro 2000 is mounted to sparco sliders and I guess I could remove them however prefer to keep them but may not have any choice.
Can side mount rails be attached to the sliders for the install or will I be forced to get rid of the sliders and use only side mounts?
Buying something like this you can't fit first is a real PIA. It's not like you run to town and fit yourself and car to some race seats![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Any insight is MUCH appreciated!
I'm not familiar with your seat but in general it's a good idea to just fab your own brackets for seat mounting. There's no way a universal bracket can fit just right and it only takes basic shop tools to make brackets and they'll be right.
I'll be glad to help out with 928 seat rail dimensions if you'd like. You have seat rails that are 18" apart on the outside. You could bolt angle stock onto the top and then attatch flat plates or even the seat itself to the sides, the only height increase would be a bolt head and the angle thickness. Would a 18" envelope fit your seat? Do you have any pics of your seat?
BTW, I vote for ditching the complication and compromise of sliders.
In Your Face, Ace
Mike,
Thanks for your offer to help! I may just take you up on it just for the simple fact of getting the chance to meet up with you.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
I have not ordered the Evo 3 seat as of yet, and the only pictures I would have would be from vendor web sites and sparco usa that really does not illustrate mounting points. If your referring to pictures of how they are mounted now, let me know and I will go take a couple pictures of how they are currently. I just boxed up the Taurus XL for return shipping today, and since it's to small for me I never even tried to install it.
Currently the Sparco Pro 2000 is mounted as follows; I have two seperate heavy gauge metal plates that are mounted to the stock 928 seating points and then drilled to attach the sparco slider bracket (type J) to the plates and then to the bottom mounting points of the seat. The sliders are not as wide as the stock mounting points, so the plates close the gap. In theory, I have no problem omitting the sliders especially considering it would lower the entire mount about an inch.
In thinking about what you have suggested, I guess I could move the plates as needed and then re-drill to match the new seat and remount the plates to the stock seating points using the Sparco side mounts.
Are you suggesting to not even get the Sparco side brackets? I'm thinking brackets need to be FIA approved and therefore would need the side mounting brackets from Sparco.
Again, thanks for the generous offer!
Have you looked at the Cobra Seats? I was just sitting in several models today to try out sizes. The Standard size Sparco was by far the tightest, the Cobra Evolution was significantly more roomy in the standard size, and it comes even larger. I came away with the impression their seats had more of a range than the Sparco.
Out of curiousity, how was the Sabelt seat in other aspects? Quality, shape, support, etc.?
Wide seats often use special mounting brackets. They are the type that have a simple 90 degree bend whereas the side brackets for a normal width seat have a compound bend so that the mounting holes are positioned properly over the factory mounting points. I don't know what an EVO3 would require. i had EVO2's in my 911 and I used a homemade 90 degree bend mounting bracket. I now have COBRAs and I had to use a B-K bracket because it's made for wider seats.
In Your Face, Ace
Thx for the tip on the Cobra!
Where did you go to check out so many seat fitments?
In Your Face, Ace
In Your Face, Ace
I just emailed them for measurements because all sizes are not on the website.
Anyone using a XL Cobra want to share their measurements? Height, weight, waist, shoulder..
EDIT: Found the chart http://cobra.subesports.com/php/css....p?option=seats
I was at PST housed at Motorsports Ranch in Texas. They had a number of different seats to try out.
I found the standard size Cobra Evolution to have more room than the standard size Cobra Sebring or any other standard seat. The Evolution and Sebring come in larger sizes also. The standard Evolution fit me very well, at about 5'10, 34", 195. Cobra shell is kevlar, so they are a bit lighter than Sparco, seemed to have stronger wearing covering also.
You should try out seats, just as has been suggested. I noticed subtle differences among every one I sat in.
