Arched trailer ramps?
Old 10-29-2007, 10:03 PM
dave968M3
dave968M3's Avatar
Default Arched trailer ramps?
After being sloppy in arranging my standard 4 ft steel ramps and 4 ft pressure treated 2x8s that I use to load my 968 on my 18 ft open steel trailer, I scraped the front belly tray, ripped the lower bumper cover, and pulled off the power steering belt while driving onto my trailer. Since I always find it a pain to properly arrange the steel ramps and 2x8s anyway, I plan on purchasing some aluminum extended trailer loading ramps.
Does anybody have any advice/experience with the length that is needed to improve the loading of a lowered 968 to prevent scraping it on the trailer? I was thinking about 6 to 8 ft long ramps.
Do the arched ramps also reduce the angle and prevent scraping the car while loading?
txs
Dave
Old 10-29-2007, 10:11 PM
Abby Normal
In Your Face, Ace
Abby Normal's Avatar
I use a dove-tail trailer with cheater boards in addition to the ramps. It's the only way I can keep the spoiler from scraping.
Old 10-29-2007, 10:45 PM
kgorman
kgorman's Avatar
I don't have experience with these, but I see a lot of them in the paddock:
http://www.buffaloespeedenterprises.com/
Not sure about the arched question tho. ;-)
Old 10-29-2007, 10:49 PM
A930Rocket
A930Rocket's Avatar
I've got 6' ramps, but still need a 2x10 built 3 high to get my car loaded with out killing the front air dam. I'd like to get longer ramps, but have to place to store them on the trailer.
I got my ramps at www.discountramps.com
Old 10-30-2007, 12:18 AM
SundayDriver
Lifetime Rennlist Member
SundayDriver's Avatar
I use these and they work well. My car has ~1 1/4" front clearance and ~1 3/4 at the rear. It needs a little help with these ramps but they are, by far, the best I have used. For reference, my car also 'high-centers' on the break for the beaver tail. If you can clear the beaver tail, these ramps should work without any helpers.
Old 10-30-2007, 12:22 AM
Apex Rex
Apex Rex's Avatar
I haven't had any problems loading my 968 on an open trailex with the 8' ramps that it comes with. No scraping, and the front is pretty low on my car.
Old 10-30-2007, 12:51 AM
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
Have you tried raising the front of your trailer too? Either use the trailer jack, a floor jack or ramps for the back of your tow vehicle. You would be surprised at how much more clearance you get with a little incline to the trailer. My car is very low too, but I can just drive it up the door ramp (6') if I raise the trailer nose a foot.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 10-30-2007, 06:34 AM
smlporsche
smlporsche's Avatar
I've seen several guys either use their tongue jack to raise the car or back their tow vehicle onto a pair of Rhino ramps.
Old 10-30-2007, 08:53 AM
Bull
Bull's Avatar
+1 (2 low cars with no problem for either)
Old 10-30-2007, 12:12 PM
SMR996
SMR996's Avatar
I use these for my 996 ...... I'll have anywhere from 1/2" or more clearance when I back out of the trailer.... the best part is they weight next to nothing....
http://www.raceramps.com/store/shopexd.asp?id=73
Old 10-30-2007, 12:32 PM
JoeMag
JoeMag's Avatar
If you have enough droop in your front shocks you can make a spacer to put between spring and perch for loading. I did this for my 930. took a bar of alum 1" wide and 1/4" thick, bent two pieces in a U. little bit of a pain to jack car up just after unload and before loading, but worked well.
Old 10-30-2007, 01:41 PM
RamVA
RamVA's Avatar
+1 on the Rhino ramps - seems a cheap and easy first step if you have a clearance problem, plus they're handy for other uses.
Old 10-30-2007, 05:01 PM
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
MUSSBERGER's Avatar
I leave it hitched up to my truck and screw the jack down until the forward trailer axle wheels are just about off the ground. Works for me.
Nissan Titan, 18' Brimar beavertail, 911sc f class
Old 10-30-2007, 06:47 PM
MarkPcar
MarkPcar's Avatar
+2 - these are great. I ordered my new ATC without ramps so I could install these.
Old 10-30-2007, 10:23 PM
Bill L Seifert
Bill L Seifert's Avatar
Mussberger
I tried that, and then forgot to let the front of the trailer down, and promptly ripped the jack off the trailer. Since then, I have used ramps to back the rear wheels of the truck onto. You would have to be kind of a moron to forget those, though, I feel I am capable. So far it works.
Bill Seifert
1987 944S Race Car
Quick Reply: Arched trailer ramps?
