Corner Balance Scales
Lifetime Rennlist Member
I would add a couple of things to some of the suggestions.
Inflate tires to HOT pressures.
Set shocks full soft in addition to unfastening sway bars which was mentioned.
I don't use any slip plate but I do roll the car back and forth after each adjustment, then very slight bounces front and rear to settle.
If you are aligning, I think it is very important to roll the car back and forth, in addition to bouncing.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Setup tires are used as well. A set of wheels that the outer lip of the wheels are machined parallel to the mounting face to ensure straight wheels and accuarate toe and camber measurements. Then a sample set of tires are mounted, but not run on track and positioned on the car in the same fashion each time on the pad. Valve stems 'down' is often used such that the same part of the tires rides the scales each time. Of course this may be overkill for a road going racecar. I certainly dont have an extra set of wheels and new tires for this
R+C
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
it makes more sense to me to set the car up on the tyres it is going to race on. Do the corner balance and alignment all at the same time. A useful shortcut is to turn the scale screen and alignment screen upside down so you can read them more easily when you are under the car. I use a spreadsheet which prompts the mechanic to make the correct adjustments and also stores all set up values.
R+C
R+C
Mr. Excitement
I think you need to do both before taking readings. Bouncing unloads stiction in suspension. Rolling removes binding from tires gripping the stale surface or tucking in while the car is up. Each does a different thing. Bouncing will not remove a tuck bind. rolling might not remove a stiction bind.
Basic Site Sponsor
Basic Site Sponsor
I still like my cast iron, made in china, 50 lb turn plates. For $100 per pair, you can't beat them. The only problems is that shipping is around $100 too.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Basic Site Sponsor
Basic Site Sponsor
