Corner Balance Scales
I figured I'd cross post this here. I might get more responses.
If I was to "hypothetically" buy a set of corner balance scales, would the 1,100 lbs scales be sufficient or would I need to get the 1,500 lbs ones?
These are the Accuset scales from Long Acre.
Basic Site Sponsor
Basic Site Sponsor
I'd go for the 1500 lb units. That's what I have. More durable and if you do the math, a 3200 car like a 996 with 60% of it's weight on the rear wheels puts 960 lbs on each scale, close to 90% of the scales rating, and that is not enough margin IMHO.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
When you corner balance a car, it is important to bump (compress -- by jumping on) the suspension a few times to find the value that the suspension will settle at after you make an adjustment...which will probably push you over the limit in Larry's 996 example.
I was figuring my SC is around 2,900 lbs. So that would put the numbers around 850's in the rear.
Also, the 1,500 lbs scales are 15"x15" where as the 1,100 lbs. scales are 12"x12". I don't know if that makes a difference too.
Basic Site Sponsor
Basic Site Sponsor
Plus to really do it right you need 2 sets of turn plates (4) so that the suspension does not bind. I bought the cheap steel ones and they weight 50 lbs each, so that's another 200 lbs. Of course the lightweight aluminum ones cost 5 times as much.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
watch when you use these anti bind things (especially those will no side limits). you put it under all 4 tires and you'll amazed how easy it will be to slide your car right off the scales!
Hey Chris -- that ziplock thing is a great idea! I had been using the smooth side of two squares of bathroom wall board with grease in between then. the zip locks take away the worry about differences of height and the scale lips will help prevent what I mention above.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Mr. Excitement
Yes. kudos on a good tip too.
I am using a 12 inch plate set. Hooked up a set for cheap. I have a lift in the shop so I made a set of holders that have room for me to roll onto and off of the pads for unloading and zeroing the scales. Less space and $ taken up than with a ramp set. The holders have 4 ajustable feet each and the feet ends have nylon tips so the scale holders can slide with little binding. I lift the car and slide the pads under to preset locations where they are dead level and set the car down. The suspention settles and the holders give a little. roll on and off a couple times and go to town. Ajust and roll back and forth again. If I a car with tires that are wider than the plates I stack some 1/2 plywood on the plates to keep the tires from touching the holder frames.
I guess my technique could use some fine tuning. I'm not sure where the roll-on, roll-off parts works. Here's my technique, tell me how I can make it better.
I use a lift and put the car in the air, detach the sways, back down on the ground, bounce it on the corners, and then back up in the air. I place the scales under the tires in a pre-marked area, let them settle, and press the zero button. I then lower the car onto the scale pads, bounce the car front and rear, let it settle and take a reading. Up in the air, make an adjustment, back down, bounce front and rear, settle, take a reading and repeat.
Now are you guys saying I should also push the car in a horizontal axis (as with the baggie) after doing the bounce (vertical axis)?
