Info needed on Road Atlanta
As for the curbs, they can definitely be used in the 3 and 10. There is a secret to hitting them so it isn't too harsh on your suspension.
You can run over 3 curbs in turn 5 alone! And even in 7 it's pretty smooth after the repave. For the RA rookies the curbing in 10A and B is sort of unique, it gets progressively rougher the further you are from the ashphalt.
<=== another take on turn 3
I'll be there, too, running slowly in 5 and probably instructing in group 2
Cheers
Randy
Cheers
Randy
Peachstate PCA will try to put an instructor and student with similar/same cars together.
I'll be there next week too.
Traqmate Start/Finish Coordinates (v1.30 and later)
These are the Start/Finish Coordinates of Road Atlanta (updated for v1.30 and later)
Lat 34.150367 decimal degrees
Lon -83.814176 decimal degrees
Heading 122 degrees
I'll be at the DE too - hope to see you there.
Heading 122 degrees
Turn 3 curbing really throws my car off. I think Forza is going off of what it was before the repave, the curbing at 3 was exactly like it is on forza, you could use the whole thing, easily.
