Recaro Pole Position vs Recaro Profi SPG
I'm 6' 155 and SPG is tight. Works great and holds me snug on track but I drive my car on the street sometimes for 3 hrs to COTA so I got SPG XL. Still much much more supportive than GT2/CGT buckets but comfy for longer drives.
I am 6 ft and 210 lb and the PP fits me very well. The SPG was too tight.
I drive 4 hours to WG comfortably with a few stops, although I have some additional custom cushions I made to make street use more comfortable.
The shoulder belt hole size/location may be a problem for you, especially if you plan on using a HANS (which I do).
Mike
Mike
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/orvbtut_ta_wnhtqpgyblq_e1cfc9b866a4f0bd69adf45b70266f20e402cf09.jpg)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/0wmverz3qcqocw9uj0qkgg_b47edba152f0bbb10e60991cf01d5eb1fe8dc374.jpg)
I'm looking to buy a pair of track seats to replace my OEM Sport Seats - they're for sale BTW
Problem is, I can't figure out the difference between Recaro's Pole Position and SPG seats other than price.
I'm using the car for Street/DE and would like a comfortable seat for the long treks to the Glen for instance.
Any idea which one is better and why?
Thanks!
Thanks!
I AM 200 ibs, 181cm tall, should get the pole position or spg? thank you.
I am 6ft and 203 Ibs. should i get the pole position or spg
I am 6'2" and 240 lb 36" waist 34" inseam and I used to have a Profi XL in the driver seat at Profi SPG in the passenger seat. I could not fit into the Profi SPG, it was like a child seat, and my wife (5'6" and 180 lb) could fit but it was TIGHT, but she has wider hips.
My understanding is the pole position has a wider base like the Profi XL, but the pole position shoulder harness pass through holes are kind of low where the Profi SPG is higher. I am not sure where you are located but at your next track day, see if you can sit in as many cars as you can to see how the seats fit. I bought a Cobra Halo seat online one time that would have been perfect but my shoulders were too wide to fit the wings, so my advice is always to sit in the seat first, but hopefully my sizes and comparisons will give you a data point.
Received 1,786 Likes
5'10", AROUND 215 LBS (DOWN FROM 300 2 YEARS AGO WHEN I BOUHGT THE SEATS).
I got the XL's as that's all I fit into at the 300 lb. time.
Now at 215, I still fit into them, just a bit more comfortably so I strap in a bit tighter I guess. Still fit them fine.
Love the XL's. Very comfy, good support.
Looking back, I shoulda gotten the Halo's, so I guess that's next.
Good luck.....
Good luck.....
steved0x (07-07-2020)
I am 6'2", 230lbs, how are you thoughts on the PP? Will I fit? I am about to order for an upcoming track day and here in Slovakia there is absolutely no way I can check fitment in advance.
Happy to hear other opinions!
Thanks!
Just curious, what are your thoughts for 6'2" 230, thoughts on fitment?
Thanks!
