Anyone try Hoosier 275/35/15 tires?
Old 07-22-2007 | 02:48 PM
analogmike's Avatar
analogmike
Default Anyone try Hoosier 275/35/15 tires?
I see that Hoosier has a new P275/35ZR15 size, only 23" tall!
Could be fun on the back of an early 911 with 9 x 15. Like a short R & P...
Anyone tried them yet?
Old 07-22-2007 | 04:12 PM
Lemming's Avatar
Lemming
I saw that as well and am considering trying them once my GTR conversion is finished in the fall. The problem is, where do you find 15x9 Porsche wheels?
Old 07-22-2007 | 06:28 PM
pu911rsr's Avatar
pu911rsr
Factory 15 x 9 fuchs are rare and expensive. Many people can make a set up for you from 15 x 6's. There are some good repops being made as well. There are also quite a few after market chioces, BBS's Gotti's etc.
Phil
Old 07-22-2007 | 10:58 PM
Slantnose!'s Avatar
Slantnose!
Yes, that is a great new tire...nice size, too.
Kind-of the hot set-up around here
Old 07-23-2007 | 03:50 PM
analogmike's Avatar
analogmike
I have a few sets of BBS 8s and 9s x 15. But the offset in the rear is FAR OUT, I doubt they will fit
Old 07-23-2007 | 04:11 PM
Slantnose!'s Avatar
Slantnose!
Yeah, doesn't look very likely.
Not sure what size that tire is, but believe that the new tire tread might be as wide as your existing sidewall, but then again shorter, too.
Might be worth a try.
Old 07-23-2007 | 05:46 PM
analogmike's Avatar
analogmike
I was thinking the shortness might help, which allows me to run 225/45/15 on 930 turbo rears on the front though they seem to stick out.
But these are WIDE, 10" tread width as opposed to the 245/45s seen above which are 8.5" wide. But the 245s are 24" tall, these are 23" so 1/2 shorter... will have to do some testing.
Old 07-23-2007 | 06:10 PM
Conekiller's Avatar
Conekiller
Mike
what are the offset's on those wheels? I'm looking for a set of 15x9 so i can run the 275/35/15
Old 07-23-2007 | 06:56 PM
analogmike's Avatar
analogmike
These are like the RSR wheels, only 2 or 3mm offset, really stick out... but they look great as they make the car W I D E !
I might have an extra set of the 9s (no matching 8s, I was using Fuchs 8s on the front)
Old 07-24-2007 | 12:08 AM
Azikara's Avatar
Azikara
What other options are there? I can see getting some custom Kodiaks or Jongbloed. It's hard to try and find these in 8/9.
I've seen some people using 15" on the front and 16" on the rear of a 911. What is the advantage to this? Better braking efficiency?
Old 07-24-2007 | 01:21 PM
analogmike's Avatar
analogmike
There are lots of cheap 15" autocross wheels you can have custom made, but not sure I would use them on the track. Jongbloed are expensive and they ask for too much info to build the wheels.
I use 15x8 front and 16x9 rear so I can use stock Fuchs wheels and get the most tire under the car, with the lowest ride height. 17s or 18s would be faster, will upgrade if needed.
Old 07-24-2007 | 04:14 PM
pu911rsr's Avatar
pu911rsr
Mike,
Check out the Complete Custom Wheels and Kodiak's, much more reasonable.
Phil
Old 07-24-2007 | 05:45 PM
Lemming's Avatar
Lemming
Originally Posted by pu911rsr
Mike,
Phil
CCW won't make 15's, I've already asked
Old 07-24-2007 | 08:37 PM
Azikara's Avatar
Azikara
Why do you say the 17 or 18s will be faster? there's more force applied to the road for the same torque. For those of us that have the long 915 transmission this is a good thing.
