Trail Braking Instruction Strategies
#46
Indeed, Joe;
Your idea has definite merit. I sort of knew where you were going with that thought, but, but, comfort zones are so... well... comfortable!
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
#47
Adendum from your respectful instructor and student.
Want to learn to trail brake?
Drive Calabogie!
If you want to even approach being quick, there are a ton of places that you HAVE to TB. Exceptionally instructional weekend from that standpoint alone!!!
I can also now clearly see the wisdom of tuning for slight understeer. This will keep the rear of the car from jumping out on you, which will allow you to carry a TON of speed very deep into the corners without soiling yourself, and will also force you to trail brake to get the car to rotate and/or slow to the point where it will rotate under trailing throttle on VERY late apex corners.
Drive Calabogie!
#49
What I struggle with is what is the ideal time to down shift when TB. Is it before turn in, but with bigger throttle blip not to buzz the engine or just before transitioning to gas at/near apex?
#50
Drive Calabogie!
Drive Calabogie!
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#51
#52
IE... the guy that can brake, downshift and turn all at the same time if that is right for the corner will be faster than the guy that must give-up a little bit to brake, downshift, or turn a bit early or late because he cannot do all at the same time.
#53
The proper time is the same; when doing so does not stand to wing the engine and/or upset the chassis. The PLACE will be far deeper into the turn because the TB allows you to go deeper with more speed.
#54
Originally Posted by 38D
downshifting like braking can happen anywhere...it all depends on the turn and the number of shifts.
yep. At the decreasing radius corner (which begs for trailbraking) at Calabogie, my 4->3 downshift is mid-corner. Most times, it's as late as I can in the braking zone without upsetting the car.
John: glad to hear to into the trailbraking groove. It's a definite asset at tracks like Calabogie.
#55
Basic Site Sponsor
Basic Site Sponsor
Guys, I posted this video a while ago about downshifting, but the first turn is a good example of downshifting AND trailbraking, IMHO. I do 2 downshifts underbraking (5-3 & 3-2) and carry it very deep into turn 1. When I go to the gas, it is right to the floor.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Last edited by Larry Herman; 07-18-2007 at 10:53 PM. Reason: changing the link to one that works!
#56
Larry, the link says page can not be found.
#57
Basic Site Sponsor
Basic Site Sponsor
#58
Hi Guys,
I've read through this reasonably thoroughly and have not noticed much said about Left foot braking. Apologies if there have been many references, I have skimmed a little, however to me it seems much easier to TB with lfb than rfb. I have an auto sedan that I use as a daily driver and I LFB about 80% of the time and it is the best practice short of dedicated track time. Very easy to get used to and something that you can really take to the track as your modulation improves out of sight very quickly. You wind up LFTB every 2nd corner or something like that. It makes the boring drive to and from work a bit more fun.
#59
Indeed;
I LFB right from the start in every situation where a downshift is not required. When a shift is required, I switch my feet after the shift is completed. In other words, I LFB in almost every corner, TB or not.
