Tool for spreading caliper pistons on 997S
Super Duper Moderator
Originally Posted by Toby Pennycuff
...Do you mean this tool?...
Marc
1 Post
I bought one of these cheapo spreaders and then couldn't figure out how to make it work on my 911. So I went back to the small pry bar method. The only thing I worry about with the pry bar method is possibly bending or warping something that I'm lever against.
While we're on this topic, what do you guys use for pad removal tools? Just grap the end of the pads with big pliers? Do you use anything that hooks into the two little holes in the pad backing plates?
Rennlist Hoonigan
which cost no drachmas
[QUOTE=TR6]I bought one of these cheapo spreaders and then couldn't figure out how to make it work on my 911. QUOTE]
That won't work on your 911.
I have one of the Eagle Day ones that I'll sell, now that I no longer have a 993....PM me if interested.
Edit:
SOLD
Edit:
SOLD
Moderator
Don't waste your time and money on a specialty tool -- as was mentioned, a set of channel locks that everyone has with something to cushion the pressure on the caliper is all you need. Squeeze the retaining pin hole in a pad to the outside of the caliper for both inboard and outboard pads and you are done. About 5 minutes per corner - so 30 minutes for a set. All I use for the process is 1) Channel Locks, 2) small screwdriver to pull out the cotter pin and then push through the retaining pin. That's it - 2 tools...
Capt Steve (12-17-2022)
True, there are cheaper ways to get the job done. But this tool turns the 30 minute job into a 5-10 minute job. Plus there are occasions when my pry bar/old pad method didn't go as smoothly as planned. Never so with the specialty tool. It doesn't take too many pad changes for the investment to pay off. The analogy of using an impact gun to remove wheels was a good one. You don't NEED an impact gun, but it sure makes the job easier and once you try it you never want to go back.
I've found trigger clamps work more easily than the channel locks, seems like I can get more leverage. Work on one side at a time, squeeze the pad against the outside of the caliper with a few quick pumps on the trigger. Plus it's rubber coated, so don't have to worry about scratching the calipers, which I was worried about if the channel locks slipped. Not sure if it would work if the brakes are hot though.
I'd never give up the DeWalt cordless impact after being spoiled by it and I'd never go back to fumbling with pliers, screwdrivers, prybars, and rags as padding again!
Marc
The Penguin King
That Snap On one works great, and not that expensive compared to the others.
Just thank Porsche for not going to the push and turn pistons like Audi, Acura, and some others.
