How fast do Hoosiers go off?
Old 06-05-2007, 05:09 PM
analogmike
analogmike's Avatar
Originally Posted by Slantnose!
I've found you need to scrub them in first and then let them sit longer than overnight, closer to 24 hours.
Even adding an extra 4 psi or so and doing some figures eights in front of the
I find that too, they are not great when they are new. I had to get a new set for Atlanta as I fried my Sebring set in a spin. They were OK in Atlanta but the car never really hooked up. The rears were heat cycled by The Tire Rack, I thought that would help. But for the 2nd race (Lime Rock) they were amazing, then I'm sure they will be excellent for several more races. I have not found R6s end of life yet actually (my other set has about 10 races and still fine). Of course my '73 is light and easy on tires...
Old 06-05-2007, 05:15 PM
93 FireHawk 968
93 FireHawk 968's Avatar
Although I'm no expert I have used Hossiers solely for 4 years and the R6'S have lasted the longest. I have 2 sets with close to 12 heat cycles on them and the grip is still good. Certainly not what it was after the first cycle but not a huge drop off like R4's and 5's. Colder starting temps are a must with the R6's with a goal of high 30's when hot. Uniform tire temps are experienced with all 4 with my current suspension set up which may be adding to the longevity.
Old 06-05-2007, 05:17 PM
richard glickel.
richard glickel.'s Avatar
Hi Joe.
Old 06-05-2007, 05:18 PM
PedroNole
PedroNole's Avatar
At least 8-10 heat cycles unless those are done on a dyno. A dyno kills Hoosiers.....
I'll say this, the best way to get the most out of them is to scuff them, bleed some air and put them away for 24-48 hours. I have found that it's all about the initial scuff.
Old 06-05-2007, 05:21 PM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,607 Likes on 836 Posts
Originally Posted by Bull
TD, I'm sure you are talking about R6s, which i find drop off a little after 6-8 heat cycles, but rememain consistent after that for quite a while. My experience with R6s is that they do what you describe when they get the least bit above 37-38 psi. I target 35-36psi.
VR, are you talking about R6s, or older Hoosiers? Most people I run with find that the new R6s last much longer than the older Hosiers.
Older ones. I have zero seat time with R6's.
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
Try them, you'll like them.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 06-05-2007, 05:31 PM
Veloce Raptor
so i have heard
Old 06-05-2007, 05:34 PM
Lemming
Lemming's Avatar
You guys are going to kill my budget
Old 06-05-2007, 05:36 PM
TD in DC
TD in DC's Avatar
I will say that they are extremely predictable. They feel more like street tires in that regard, or maybe I am just so used to them now that I have forgotten what it is like to drive street tires in a DE.
Old 06-05-2007, 05:40 PM
George A
George A's Avatar
so i have heard
Hey, you can try them on my car.
G.
Old 06-05-2007, 06:34 PM
Ed Newman
Ed Newman's Avatar
Hoosiers are definitely fastest the first 3-4 heat cycles. As for the experiences in Sprint # 2, I have a feeling it had to do more with the track, temp and tire pressues. I had the same feeling that there was not as much grip during the second race. I think it was just the higher temps led to higher pressures and the car not gripping as well. I can feel a noticable difference in traction with only 2-3 psi high in the rear tires. I ended up 4-5 psi high at the end of the second sprint race after dropping 1 psi from the tires after the morning to prep for hotter temps in the PM. This was reflected in my times which were a 2-3 seconds slower per lap in the PM race.
Old 06-05-2007, 06:41 PM
Veloce Raptor
G.
Wow, that is very nice of you, mang. When?
Old 06-05-2007, 06:44 PM
Sean F
NASA Racer
Sean F's Avatar
Todd, overall the times were off in #2 compared to the first sprint. I found it more difficult to put down a good time in the second sprint. My times were off 1-2 seconds. My pressures were good, just didn't seem like I had the same grip.
TD in DC
TD in DC's Avatar
You could be right. I had just assumed it was my tires because nobody else seemed to be experiencing this looseness in the second sprint and enduro.
Sean F
NASA Racer
Sean F's Avatar
Let's hope this doesn't turn into a "can I drove your car" thread
Quick Reply: How fast do Hoosiers go off?
