Helmets
UAE Rennlist Ambassador
Helmets
Going to buy a new helment, aiming to hit the track this summer at the local track.
is there anything specific one should look for when getting a new helmet?
Is there a difference between bike helments and car helmets or are they the same?
Thanks!
Thanks!
Thanks!
Thanks!
car helmets are designed for multiple tiny impacts (due to the helmet bouncing off the roll cages now and then)
other than that, the pricer a helmet is, chances are it is a) lighter b) has more features c) better cloth/more ergonomic design
dont forget that to get a hans device a helmet needs to be modified with the appropriate tabs, the more expensive helmets will usualy come pre-build
also, try to get white, less heat
Documenter of Ineptitude
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The thing to look for first is, fit and second is does it meet the regulations set forth by the people you are driving with.
Bike helmets are usually not built with fireproof lining and require are larger eyeport.
Car helmets can have a smaller opening and have a fire proof lining.
Originally Posted by fork_included
bike helmets (M rating) are designed for one big serious crash afterwhich they should (theoreticaly) be replaced
This misinformation keeps getting passed around as gospel. It's not. It's just not that simple. Some helmets may be designed differently for cars and/or for bikes, but certainly not all (other than Nomex liner). There have been many shells that manufacturers use for both bike and car helmets.
What is different is the requirements to meet the different Snell ratings. For the run down on this go directly to the source:
http://www.smf.org/
The basic differences in the ratings are:
1) Size of the allowed or required eye port
2) SA must have a fire resistant liner
3) SA must pass one additional anvil test
All helmets that have been impacted should be replaced immediately.
From the Snell Memorial Foundation site:
What are the differences between the SA, M and K standards?
The SA standard was designed for competitive auto racing while M standard was for motorcycling and other motorsports. The K standard was released to accommodate helmets used in karting. There are three major differences between them:
1. The SA standard requires flammability test while the M and K standards do not.
2. The SA and K standards allow for a narrower visual field than M standard (Some SA and K certified helmets may not be street legal).
3. The SA and K standards include a rollbar multi impact test while M standard does not.
If you read the actual test protocols, IIRC you will find the only difference is the addition of a 3rd anvil test. Bikes have to pass with two anvils. Also, IIRC both get multiple impacts on each anvil. It's been a while since I read both protocols, but I'm pretty sure that's it. The third anvil is the so-called "rollbar multi impact" test.
While I agree with this, I would switch the order. Make sure it passes the safety requirement of the clubs in your area. If you don't have a motorcycle, get SA rated. Many clubs won't allow M helmets.
If this will be your first track venture, maybe renting a helmet to see if you even like the track is the better path.
Get one that fits while wearing a Balaclava too. They make the helmet smell better longer.
Yep... Balaclavas great to reduce sweat in the linings, and as cooley said... test fit with the balaclava. Otherwise a good fit with out will be tight withone.
Once you setle on the ratings, fit is the most important aspect of buying the helmet. I recommend you do not do this over the internet or phone. I recently purchased an SA rated helmet and tried on about a dozen different makes and models. Some of the more expensive helmets did not necessarily fit better or have a superior eyeport. I ended up buying a lower priced SA rated helmet based on fit not cost.
Good luck!
Good luck!
Wow, never knew there was so much into a helmet, good thing i posted here then, thanks everyone for this.
Now, the problem is, i cannot find a shop that sells helmets that fit me, i was going to get one online, but looks like it wouldn't be for the best.
What about those car helmets that look like bike helmets, the ones with a visor to cover you're eyes, is that a more desired feature to keep everything away from you're eyes incase (god forbid) a crash/roll over occures?
Formula One Spin Doctor
I would look into the arai helmets , These are specially made to absorb major frontal impacts without damage , Tony kaana wears one to protect his snout ..
Let me also ask if anyone has any comments on Schuberth helmets -- I hear Schumacher wears one, but I haven't seen these in any of the NY/NJ/CT shops I've been to.
