Weight or Power?
Old 05-07-2007, 05:35 PM
Cory M
Cory M's Avatar
Default Weight or Power?
What would you rather have, 20% more power or 20% less weight?
I'm getting started on a 911 racecar project and I have a couple of options to consider. In the class I have in mind I can have a 2650 pound car with around 220 HP, or a 2200 pound car with about 180 HP (weights include driver). Either car will be identical (aero, suspension, tires) other the power plant - the only differences will be the power and weight. I know the best combo is track dependent but I am looking for the best all around performer.
Right now I am leaning towards building the lighter car. I feel that the lower weight will help me all around - acceleration, braking, and cornering; while the extra power will only help me accelerate. The lighter car should also be easier on consumables like brakes and tires. I have been pretty impressed with some of the lightweight vintage 911's that race out here, although most of them have high dollar race motors they are only 2 litres, and they are really quick running on skinny 225 rubber.
What would you build and why?
Old 05-07-2007, 05:43 PM
Bryan Watts
Bryan Watts's Avatar
Definitely lighter for all of the reasons you listed...same power/weight = same acceleration, but lighter weight means the car will corner and brake better. Also, try to use a motor setup that will get you that peak hp # you need while maximizing area under the curve. HP doesn't win races, power under the curve does.
Old 05-07-2007, 05:45 PM
Bailey-86-MA
Bailey-86-MA's Avatar
Slightly greater power to weight ratio in the lighter car.
Old 05-07-2007, 05:51 PM
Bryan Watts
12.0 vs. 12.2 lbs per hp...I'm assuming his weights are just examples and the class he's looking to run limits him to a 12:1 ratio. Looks like he's shooting for GTS3 on slicks in NASA GTS.
Old 05-07-2007, 05:53 PM
Garen
Garen's Avatar
weight all the way... power can come later.
Old 05-07-2007, 05:54 PM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,680 Likes on 868 Posts
+1
Old 05-07-2007, 05:59 PM
2BWise
2BWise's Avatar
Personally, I would take the lighter car. It will out perform the heavy car in most categories, but there is a point where price and amount of work come in to play. Is it going to be more expensive and time consuming to get the motor to 220 hp or to get the chassis to 2200 lbs? Any left over funds get to go towards better/more tires, brakes, different springs (depending on whether you're on torsion bars or not and the feasibility of swapping), etc.
Old 05-07-2007, 06:04 PM
38D
38D's Avatar
Power/weight governs handling, braking and launch out of the turn. Peak hp does matters for top end. If you raced at Daytona, you'd want the 2650/220 car. At most other tracks, you'd want the 2200/180.
Old 05-07-2007, 06:08 PM
gbaker
gbaker's Avatar
Lighter. Everything gets better, as you noted.
Old 05-07-2007, 06:10 PM
Cory M
Cory M's Avatar
It is cheaper and easier for me to make the car light so that is part of my motivation too. Fiberglass parts are a lot cheaper than 911 engine swaps.
Would your answer change if I said half of my racers will be at Willow Springs and Cal Speedway (both are "fast" tracks)?
Old 05-07-2007, 06:31 PM
krC2S
krC2S's Avatar
lighter..weight is the enemey!
2200/180 is much better car than a 2600/220 car IMO
Old 05-07-2007, 08:12 PM
JackOlsen
JackOlsen's Avatar
Power gets you tenths. Weight gets you seconds.
Old 05-07-2007, 08:26 PM
smlporsche
smlporsche's Avatar
'Nuff said....
Old 05-07-2007, 10:11 PM
A.Wayne
Formula One Spin Doctor
A.Wayne's Avatar
The lighter car , less load on the tires and brakes , bigger advantage over the race distance ..... A really nice race car weight is 1800 lbs , 2600 will feel like a truck...
Old 05-08-2007, 04:10 AM
IcemanG17
IcemanG17's Avatar
Since the power/weight difference isn't very much.....I would go for the lighter car.....with only a .2 difference in power/weight the 450lbs lighter car will turn better lap times!
Quick Reply: Weight or Power?
