Getting gunk off DOT Cmpd tires
Old 04-27-2007 | 11:32 AM
M758's Avatar
M758
Originally Posted by chris walrod
pickup can cause wheel imbalance. once you scrape a set of tires, you'll quickly learn how much weight in rubber comes off tires.
That is all true, but in my experience a lap or two on track clears the tires so would that not be the easiest thing? I can understand pulling rubber from the inside of the wheel.
Old 04-27-2007 | 11:53 AM
chrisp's Avatar
chrisp
Is the car street-able? If so, a couple of miles should take care of it.
Old 04-27-2007 | 12:16 PM
RXDOC's Avatar
RXDOC
Originally Posted by M758
Honestly I agree. Tire pick up has never been concern. I just am sure to do a little bit of side to side driving to ensure clean tires before the start of race and try not pick up too much crap at the end of a session, but that is about it. I have NEVER seen any one picking rubber off their tires. Is the rubber build up causing a problem.
Thanks guys, I should have presented my problem more clearly. I just bought a set of SSR GT-S light-weight wheels that came with a set of Yoko Advan AO48 tires. The tires look to be in good shape but 2 have this sizeable tar/asphalt (whatever) build-up. It's a strip running around the tire 2-3inches wide (variable size). I am going to get the wheels balanced and use them on the track only.
Old 04-27-2007 | 12:22 PM
M758's Avatar
M758
I would not balance the tire with all that crap on it. If the tire came already mounted to the wheel I'd just drive it. All that crap should come off pretty quckly and then it should be fine. You could make the balance worse if you rebalance with crap on there and then it comes off at 2-3 laps on the track.
If you have tire service at the track you can always run a session and it the tire vibrates too much have them balance at the track.
Old 04-27-2007 | 12:23 PM
TD in DC's Avatar
TD in DC
Take it to a race shop that deals with tires. Most racing tire shops have the ability to shave tires. Just ask them to clean up the tire before they balance it. A good shop would do it without you even asking in the first place.
Old 04-27-2007 | 12:34 PM
RXDOC's Avatar
RXDOC
Joe P. and TD:
Thanks guys, I think I will either run them on the track, or get them cleaned up first and then high speed balanced.
Old 04-27-2007 | 12:35 PM
M758's Avatar
M758
I get my tires shaved (RA-1) and my guy won't shave tires that have been run. It is very easy to damage the cutting blades from imbedded rocks and such. I think this is par for course on shaving.
Old 04-27-2007 | 12:37 PM
Glen's Avatar
Glen
Drive faster...online....
Old 04-27-2007 | 12:44 PM
RXDOC's Avatar
RXDOC
OK, back to the hacksaw/file idea.
Old 04-27-2007 | 02:14 PM
Jim Clark's Avatar
Jim Clark
Unless you need or want to balance the wheels/tires just drive it off...
Old 04-27-2007 | 04:39 PM
srf506's Avatar
srf506
Yep a little on-track warm-up with some side-to-side swerving should take care of the problem. In the future try and stay on the clean parts of the track and paddock on cool-down.
PS unless you're really sure about the tires pedigrees I'd put fresh rubber on and get 'em balanced.
Old 04-27-2007 | 07:37 PM
TheOtherEric's Avatar
TheOtherEric
I like to peel off the 2 or 3 biggest rubber pieces, put them in a ziploc baggie, and mail back to Hoosier with a big label saying:
"USE FOR BREEDING PURPOSES."
Old 04-27-2007 | 08:11 PM
Greg Smith's Avatar
Greg Smith
Originally Posted by RXDOC
11 RESPONSES
2 helpfull
a few humorous
a few useless
the last one............ no catagory
Well I'm glad I could be of no help to you . But it was an honest question, what does it matter? Are you the type of person that details their car inbetween sessions? And yes, I have seen people do that.
Old 04-28-2007 | 09:33 AM
strandolph's Avatar
strandolph
You need clean tires for suspension setup. One big blob of track rubber in the wrong spot and your camber reading is off by 1/2 degree...
Steve
Quick Reply: Getting gunk off DOT Cmpd tires
