Weight distribution hitches
do you need to purchase the weight rating closest to the tongue weight being pulled or is it recommend to go up one or two levels? For example, my trailer loaded is 4,500 lbs. Assuming 10% tongue weight (450 lbs) do I buy the 500 lb max capacity, 700 lb capacity, or 1000?
BTW, I really really like the Reese with trunnion style and the cam action antisway. If i'd known it would work this well and be this much better I'd have spent the money years ago. I'd get nothing different next time around.
http://www.reese-hitches.com/WD/dt_strait_line.html
The 40485 is all you need. If you just want the higher weight the cost stays the same. But since you will only be 'levering' 450 into your tow chassis there's no point really.
I am calling around trying to learn about these and seem to be getting mixed answers to the round vs. trunnion question. Most say round are easier to live with. One dealer even said the market is trending towards round and he thinks in 2-3 years trunnion will be gone.
What are the pros/cons to each design?
Originally Posted by dmilzoff
Are weight distribution hitchs helpful for open (ie. lighter weight) trailer. I tow my 944 on a steel open trailer and have not had a problem but I would consider anything to make towing safer.
David
David
What is your tow rig?
I tow my 944 behind my 2500 Dodge V10. I can tow it just fine even without trailer brakes. (I know I should run them any nearly always do, but they have flaked out when I had some wiring issues and the truck can still stop things when they do.) The Dodge is that much overkill.
However if you are towing with a mid size truck or SUV and rear end sags definitly get a wt distributing hitch. Used to tow this same car & trailer behind my 4.0L Jeep Cherokee. It would work, but needed wt distrubting hitch badly.
take a look at the equal-i-zer hitches. the drop on the hitch helps to distribute the tongue weight so the tow vehicle remains flat. the bars on the side are the anti-sway devices.
i have the 10,000lb antisway model used on my 24' enclosed carson trailer. if you really want to go all out, check out the hensley device at www.nosway.com
![](http://i40.photobucket.com/albums/e238/hayaku57/SANY0072.jpg)
