Adjustable Swaybars For 996?
I'm looking for a set of adjustable anti-rollbars for by 2001 996 C2 Coupe with sport suspension. The best I've come up with is a kit from Eibach but only the rear is adjustable. Does anyone have experience with this kit? How does it alter the balance and characteristics of the car? Has anyone found anything else?
Thanks,
Thanks,
RL Technical Advisor
Hi:
Installing a set of adjustable swaybars on your 996 C2 is no problem, we use the GT-3 ones but you must have coilovers. They will not work with the OEM non-threaded struts & shocks.
We've done quite a few of these now and use the H&R coilover setup with the GT-3 swaybars. Those have 5 adjustments in the front and 4 in the rear with adjustable droplinks, too.
Hope this helps,
Hope this helps,
