Oh no! (Yet another tow vehicle thread)
#136
Nicely done Z. Purple seems to be fitting for you.
Have fun with it, and remember to bring a nicely stocked full size cooler with ya out to Mid-Ohio. A wide assortment of beverages would work nicely.
#137
I will be sure to have assorted chilled beverages for all out Mid-Ohio...
...who DON'T state that I have a purple truck. Apex - you'll have to ask your dad to mooch a drink from me.
-Z-man.
#138
Originally Posted by Z-man
Question about hitches --
How important is it to have a weight distributing hitch? I know that it helps significantly with heavier enclosed trailers, but how beneficial is one for a lighter, open trailer - 4,000 to 5,000 lbs. max? (Figure the truck is rated for ~ 7000 lb towing capacity).
Thanks,
-Z
Thanks,
-Z
I tow my TRAILEX with an FJ Cruiser which has the 4 Runner running gear with the V6, It tows fine.
David
#139
Originally Posted by David K.
Your TRAILEX is not setup for a weight distributing hitch and it is not needed.
David
David
#140
Who needs a cooler if you have an in-bed storage area complete with drain plugs?
-Z-man.
-Z-man.
#141
Z does have a welder's special aircraft carrier, wood deck vintage. I knew 38D was his idol, but didn't expect him to copy his colors!
As I have said elsewhere, with that tonneau cover, etc., he is one cow bell and some dry ice away from starting a Good Humor route in his neighborhood!
Good luck with it Z! (the truck, not the route).
#142
It IS purple.
