Hoosier tire size question
#46
Larry: So I have to have solid bushing? if so which ones, and what sorce?
I did talk to Bob, he said that each car is different they should work but well each car is different.
If I have to order springs today for the 23rd of Feb would H&R Reds be good? Can I keep the stock shocks?
#47
Basic Site Sponsor
Basic Site Sponsor
Derek, suspension design is really more of a system approach, and not just an "I need this, I need that". I raced a 911 Carrera for may years with stock bushings and 7" & 8" wheels with 225s & 245s. It worked great. Problem was that I wanted to run wider wheels and lower profile tires. I already had the stiffer suspension so I was not concerned with body roll & losing camber. But to do so, I needed to "locate them" better inside the fenders, and had to go to solid bushings. A side benefit was better control of the suspension members for improved geometry under load.
If you are going to run 225s/245s on 7s & 8s, they will probably fit fine, as long as your wheel offset is correct. If you go to 8s & 9s, you should still be ok, but you may need stiffer springs and shocks because they may rub if the car "compresses" too much.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
#48
Larry,
Thanks for the help, I am learning about these cars as I go.
On my 1972 I sold I have done all this already, and well now it time to start over.
Long term, I plan to change both the springs and shocks out, and sways and bushings, along with brakes and mounts.
But for right now, I have a event that I what to get used to the car with , and well I already bought the 225/ 275s . That is why I what to make sure I can run them that weekend with out much rubbing.
I was looking at spring, but no spring really gives the rates like T bars do.
SO I was think of putting the H&R reds on the make sure she is really tight for the weekend.
OR can I use the Sports?
And then put the Bilsten HDs . in another month or so.
So I am really just making sure that I can run these 225/275 that weekend coming up soon.
Thanks for any insight you can provide
#49
Basic Site Sponsor
Basic Site Sponsor
Spring rates are measured in inch/lbs. So a 600 lb spring will compress 1" if you put 600 lbs directly on it. That is pretty much what happens in a McPherson strut car. Torsion bars cars, though easy to say I have a 22mm, 24mm, 30mm etc bar, there is no direct correlation to rate because the rate of both front and rear T-bars are affected by the moment arm (the length of the arm to the ball joint or rear hub). I know that the info is out there to compare their effective rate to coil springs.
BTW springs really are easier, except that H&R and other companies like to make these "packages" to sell as upgrades. A red colored spring is meaningless. What is the rate?
#50
Larry, what spring rates would you recommend for a stock C class 965; this car is also a street car and planning on getting the JIC Cross system.
I plan to run 245s on 9" and 315s on 10.5"; any suggestions?
Thx.
Thx.
#51
Basic Site Sponsor
Basic Site Sponsor
Thx.
Thx.
Actually Colin (38D) ran 700/900 on his '91 965. I don't think that you want to be any stiffer than that for occasional street use. I assume that you are running a 3.3 in prepared, because it was my understanding that you cannot get anything wider than 295s under the stock rear fenders.
#52
actually i'm running in a 3.6T and currently using h&r coilovers with only 275 front and 325 LB rear springs. I'm thinking about using the 048s 315s as they fit slightly narrower so i think they may work.
I don't have any experience with the Hoosiers however i have used the MPSC, Corsas, and 048s; do they make a hugh difference? or a 2 sec diff??
Well it looks like you will be in my class, so I suggest stock springs.
#54
Note that if you are running a heavy car like an E class C2 or a Turbo, the 285/30/18 tires may not have enough load capacity and can blow out. Maybe they fixed the problem but back when I was running E against a fast C2, he would blow out a rear tire nearly every day until he got a size with more air (more capacity).
#57
Basic Site Sponsor
Basic Site Sponsor
Originally Posted by deoxford
Ok Guys, I mounted the tires and they seem to fit all around with no rubbing, BUT There only seems to be about 1/4 inch clearance from the oil tube, is that enough?
