electric or surge trailer brakes?
Originally Posted by kgorman
You can do something! Hit the gas!
While "more gas" fixes tankslappers on motorcycles and in front-wheel drive cars, it is generally not a "crisis management" technique applicable to trailer towing.
Lifetime Rennlist Member
"Hit the gas" would have been really ugly.
Originally Posted by mbb993
About to pull the trigger on a trailer. Probably will go with a Trailex
I am undecided about brake choice. What are the advantages/disadvantages of electric-vs-surge brakes?
Will be pulling with an F150.
Thanks for the info!![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
I agree that electrics are preferable so If you are buying new, get electric. If used, don't be afraid of surge. My trailex has surge and they work fine for me. Electrics are better for calming "tail wagging" but I don't see that they stop better.
Electric are cheaper, operate better, can be adjusted on the fly, parts are cheaper, easier and less expensive to fix and less maintenance required.
Surge are less adjustable, a PITA to diagnose and fix, gotta change fluid, couplers are sensitive, don't like rust, SURGE BRAKES ARE NOT TO BE USED WITH A FRICTION SWAY CONTROL, parts are more money, they're messy when servicing. Backing up is a pain even with a reverse lockout.
We have surge brakes on some of our rental trailers only because most people don't have brake controllers. I also have them on a boat trailer. I hate them. Electric all the way.
As someone who tows virtually every week (up to 15 tons) I vote with the electric setup as well.
Just an FYI on the brake controllers, Ford started in '06 comming out with an integrated brake controller that is tied into the ABS. Very slick. It is one of the main reasons I bought my F-350 crew cab 4x4.
I have been thinking about adding this option into my truck since it didn't have it from the factory. Apparently you can just purchase the kit, and then have the truck re-flashed at the dealer to accept it. But my Prodigy works so well!
Well, I was leaning toward the electric brakes before I posted and you have all confirmed my thoughts.
My F150 is an '06 so I will look into the factory installed option. Not sure if the cost will be similar to any other controllers or not.
Are the controllers easy to install?
Thanks for all the great info!
Just got off the phone with my Ford service dept. and they informed me that as of now the new factory brake controller is only available for the F250 and up. I guess I will need to go aftermarket.
