harness loops for DAS roll bar?
Looking at a used DAS bar, painted, but without harness guide loops added.
I assumed these are usually required? Just wondering, because if they need to be welded on later, then the fact that it is already painted does not help me much. Or am I misunderstanding how the shourder harnesses are attached?
This is for a 993 coupe. Would prefer the least invasive install possible.
Thanks for any help.
Matt
Matt
Cows-4-Rent
I don't believe they are mandatory but worst case, you can weld them on then repaint the bar...no big deal at all.
The harness wrap around the cross brace the guides only hold them in position on the bar but they won't move much anyway...
They just loop around the cross bar, and there is no guide loop,...also, do a search and you'll find a lot of info to keep you busy for days on Das rollbars and the whole "safety gear complex" that needs to be there.
Mr. Excitement
If you have to have guides you can get split locking rings that are normaly used for drive shafts onblowers and the like. You can get them in 1.5 inside dia. They clamp around the bar. Get 2 per strap one for each side. No welding or painting. I thionk some of the online race shops are selling bling ones made form anodized al.
Thanks for the advice. That's good news.
Safety is definitely a system which I have decided (for me) will include FIA buckets, 6 point belts and the roll bar. Wil find a way to retain and use the 3 points for the street.
PS - any idea what a fair price for a used bar would be?
M
M
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
The best ones to buy are the ones that have been taken out of the donor car a long time ago and have been taking up valuable garage space. Motivated sellers.
