Trailer tiedown points on 993?
The shakles give room for movement of the clip while simply trying to clip to the frame does not provide enough room (from the clips of the straps I was using). The shackles work fine but can also cause some rubbing on a really low car. I now use the tow hook (relocated to front center on my car) and straps through the wheels but with the D-rings mounted outboard of the wheels so there is no rub. I use the Autometrics rear attachments.
