equipment for filling shock reservoirs
Old 05-02-2007, 08:33 AM
  #31
tar6day
tar6day's Avatar
Does the car need to be elevated, no suspension compression, b/4 filling remote reservoirs w/ nitrogen?
Old 05-02-2007, 08:35 AM
  #32
JPhillips-998
Cows-4-Rent
JPhillips-998's Avatar
Nope, on the ground is fine.
Old 05-22-2007, 10:55 AM
  #33
Alan Herod
Lifetime Member
Alan Herod's Avatar
Any updates on the utility of the new equipment people have purchased?
Old 05-22-2007, 11:15 AM
  #34
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
I use the Penske tool to set my shock pressures, and the one I built to check them. It does lose a little pressure whenever I check them, so I only use it as a precursor to setting them. On the Moton shocks, the canister pressure directly affects the compression, and so if you raise them, you must back off on the high speed compression setting. Again, the stiffer your springs, the less affect canister pressure has.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 05-22-2007, 11:26 AM
  #35
jaydubya
jaydubya's Avatar
The ProTank setup has worked great this season. No problems.
Old 02-02-2008, 10:50 AM
  #36
RickBetterley
RickBetterley's Avatar
Originally Posted by Larry Herman
It was meant only for checking the pressures. I could probably come up with something that lets you charge to a specific pressure, but that is what the other units do already.
Hi Larry
We were having conversations about an integrated shock fill and gauge setup; I hate the fill it and bleed it down method, finding it difficult to get the final pressure right.
Longacre has just come out with a combination digital gauge and fill/bleed valve (part #50473); what do you think of this set up for an accurate pressure gauge and fill device?
http://www.longacreracing.com/catalo...=1036&catid=19
Old 02-02-2008, 11:40 AM
  #37
Larry Herman
Basic Site Sponsor
Looks nice Rick. The hose makes it quite convenient. I may think about that myself, as the Penske unit that I have is one piece, and hard to maneuvour when filling my rear shocks.
Old 02-02-2008, 04:30 PM
  #38
RickBetterley
Thanks, Larry - I am having the same thought.
Old 02-02-2008, 05:17 PM
  #39
jrgordonsenior
jrgordonsenior's Avatar
How would you fill the Longacre gauge? Do you somehow put a valve stem fitting in the bottom and fill with a tire pressure chuck or filler?
Old 02-04-2008, 02:09 AM
  #40
Brian P
Brian P's Avatar
My understanding is that this is a bit like the Heisenberg uncertainty principle - i.e, the act of measuring the pressures changes the pressures.
I'm with Larry. Use a quality device to set your pressures and then don't bother measuring them. Using Karl Poetel's (sp?) advice, I put a nice T-fitting for my Schaeder valves. Basically, you set the pressure and then unscrew the plunger while leaving the nitrogen still connected. It ensures absolutely no leakage. Provided that you trust your 2-stage measurement device, your pressures should be exactly at those pressures.
Also, from what I've read, I also agree that canister pressures aren't the critically important factor. If somebody is saying they can feel the difference in canister pressures, then they are extremely sensitive to the car setup.
Old 02-06-2008, 11:51 AM
  #41
RickBetterley
I went ahead and bought the Longacre shock inflator with digital gauge as it looks like I can use it to add nitrogen to the Motons and set them to a specific pressure all at once.
Bought it from Rennlist-sponsor CDOC (Chris Lawson), who was very helpful.
I'll post a report once I get a chance to try it out.
Old 02-06-2008, 12:12 PM
  #42
Professor Helmüt Tester
Professor Helmüt Tester's Avatar
I was thinking "Schrodinger's cat", but that's the physics geek in me. Besides, your shocks probably exist, whether you have a tool to fill them or not.
Old 02-06-2008, 01:23 PM
  #43
kurt M
Mr. Excitement
kurt M's Avatar
Hats off to you sir! I was thinking of the Heisenburg principal during this thread but was afraid to bring it out. Schrodinger's cat trumps Heisenburg's geek factor.
The cat " Was that a fart?"
Old 02-06-2008, 10:06 PM
  #44
JBH
JBH's Avatar
This is what I use except the gauge reads from 0 - 300. There should be very little pressure loss and you are reading the pressure at the shock canister. If you use a long hose (like me), there is a substantial pressure drop from the tank gauge to the shock canister.
I also have a full size nitrogen tank (carried in the trailer) and a welder's two-stage pressure gauge I bought on eBay. With quick connect fittings, the nitrogen tank also fills my tires and pressurizes the brake bleeder. At some point I'll add a Snap-on impact wrench.
Old 02-06-2008, 10:46 PM
  #45
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Jeff,
FWIW,....Both Moton & JRZ specify that the shocks should be in full droop to measure and adjust gas pressures.
Quick Reply: equipment for filling shock reservoirs
