Drove Noble now I want to upgrade my 993
1. Decide where you want to go with your 993. DE only? Drive to track and back? Racing? Time trials? This will help you because all racing organizations have competition rules and classes.
2. Keep the BFG KDW's. Street tires will help you learn how to drive your car.
3. Safety first. At minimum, put in a roll bar, one piece Race seat, and 6 point harness. A cage is probably not a good idea for a car seeing regular street use.
4. From my memory, the 95 993 will need steer rack and rear suspension updates.
5. Suspensions and brakes are a system. Avoid the temptation of going at it a la carte. Your end point and pocket book will help you decide how aggressive you want to go with this.
Originally Posted by nota_troll
I have done several DEs in my M3 but only one in my prior 993. I got in a great rhythm but the WORST thing could have happened.
I drove my friend's Noble! HO BOY! What a weapon. It's balance and power was remarkable.
NOW...I need to do some reasonable track modifications. Since my car is stock I'm making my Christmas list. HWFMR members please apply.
1. Instuction every DE
2. Sell BFG KDWs (not N)
3. Install shock tower brace
4. Install PSS9s.
5. Install Camber Plates??
6. Harness? Sparco Seats?
Any thoughts?
4. Install PSS9s.
Any thoughts?
2. Wear them out, won't take too long
3. Get the right one, lot's of crap for sale out there (sure someone here knows, I use Smart Racing's on my SC)
4. Have yet to hear anyone say PSS9's are really good for the track.. (better than stock but quickly outgrown)..
5. Your local race shop should advise you on what you need to attain a good comprimise setup IF this is a street/track car
6. Roll bar at a minimum, good seats with opening for lower (between legs) belt, 5-6 point harnesses.
7. Brake pads and system flush and refill with ATE Blue or Gold. I love Performance Friction but ask around what the best combo is for a 993.
8. Check and rebuild all suspension bushings.
9. Proper helmet and approved H&N device
That's a start.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Admittedly compromise is tough but the car is my daily driver as well as my DE (only) car. I like to drive to and from the track.
Tires - I was suspecting the 'looseness' related to the tires because they aren't N rated. I'm not sure how much credence I should give to this.
Tower Brace - I bought one from Craig Traask (RL member).
Harness - After driving the Noble which has a harness I didn't realize the benefit of the secure fit. Now I'm a believer.
If it looks like you are truly hooked - start thinking about a dedicated track. The 993 with some upgrades will be fine for the short term, but it will eventually be not stiff enough for the track and/or too stiff for the street. A lot of us, myself included tried to find the holy grail of the perfect balance between street and track, and it just doesn't exist.
So, that said, your List looks good, although I would go with in a bolt-in roll bar, and get on of the Recaro or Sparco reclining seats with a sub strap slot - I had the Recaro SRD's before going with a Evo and was very happy - and clip in harnesses. That will tide you over for a while and you can determine if you're in this for the long haul and then make the jump to a dedicated track car.
Good luck - it only goes downhill from here.
A true track car would be ideal and I'm thinking of buying a friend's Elise. I guess that's my conundrum. I'm keenly aware that I'm on a path that may not take me there but if I can be content with the compromise I will do it.
My deduction is spend some money on the recreational DE setup not full track but are they one in the same? So I'm mostly considering full suspension (flavor not sure) and a harness and seat. No cage yet because I use the car almost every day and take my daugther to classes.
Thank you all.
Thank you all.
Don't do a harness without a roll bar, the stock 3 point belts are safer. I would say get a bolt in roll bar (DAS), seats and a pair of 6 point harnesses, race pads, R compounds... if you're making a track toy. If it's stll a DD I would suggest leaving it stock other than pads and track tires.
Thank you all.
Thank you all.
a) more instruction
b) shock tower brace (already have one)
c) tire pressures
Most of the PCA regions here in the Midwest allow all types of cars to run DEs..usually there is a registration for Porsche only, then after a certain date, others can apply. In our case, Kansas City Region out of Heartland Park-Topeka, we are symbiotic with KC BMW club and the Audi club. At most of our events we have everything from Z06s to Cup cars to WRXs to RX7s etc... my last group 1 student brought a Ford GT (40)! Makes for a lot of fun with all the different machinery...and competetiveness.
///Nick
///Nick
